Lots And Lots Of Oil Spewing From Timing Chain Engine Breather
74 replies to this topic
#61 imack
imack
  • 2,372 posts
Posted 07 January 2026 - 04:37 PM
OK so engine out.
My first question is, are the 2 inner small holes under the Crank, oil drain holes 20260107_133609.jpg
Yes
#62 imack
imack
  • 2,372 posts
Posted 07 January 2026 - 04:48 PM
What's going on with this corner of the 1/2 moon seal?
It wasn't shortened to install it was it?
#63 BobbyMax
BobbyMax
  • 150 posts
Posted 07 January 2026 - 05:15 PM
No not shortened just nicked the top edge when removing old gasket
Edited by BobbyMax, 07 January 2026 - 05:47 PM.
#64 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 07 January 2026 - 07:15 PM
As above the main cap doesn’t look right, it should have a recess like this
Or
https://kentautodeve...el-main-cap-set
Edited by timmy850, 07 January 2026 - 07:35 PM.
#65 BobbyMax
BobbyMax
  • 150 posts
Posted 07 January 2026 - 07:33 PM
Hi timmy your pick didnt work
#66 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 07 January 2026 - 07:37 PM
Here’s one suitable for viewers in the UK
#67 BobbyMax
BobbyMax
  • 150 posts
Posted 07 January 2026 - 07:50 PM
I see what your saying but if it was on back to front wouldent the 2 outer threaded holes be on the inside?
#68 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 07 January 2026 - 07:54 PM
I don’t think it’d fit with the gearbox casing if it was on backwards, but it does appear to only have a very small relief at the bottom to direct oil to the drain holes. It might just be a trick of the lighting or angle of your photo, but it doesn’t look like others I’ve seen
#69 BobbyMax
BobbyMax
  • 150 posts
Posted 07 January 2026 - 08:11 PM
The caps will only go on one way round.
#70 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 07 January 2026 - 08:32 PM
You can see on this block for example the drain chamfer extends down to the bottom of the drain holes, whereas yours appears to stop about halfway into the drain holes. It’s a tricky spot that is hard to find good photos of
https://www.classicm...ed-classic-mini
#71 imack
imack
  • 2,372 posts
Posted 07 January 2026 - 08:57 PM
It looks the same as all the 1275 caps I have.
#72 Lplus
Lplus
  • 990 posts
Posted 08 January 2026 - 07:26 AM
But not the same as the 1275 A+ cap I have on my spare block.  That looks like the one in posts 66 and 70.  Fair enough the cap in question  isn't on backwards, perhaps it's just a case of too much sealant blocking the holes.
#73 imack
imack
  • 2,372 posts
Posted 08 January 2026 - 10:05 AM
The one with gasket material on it is an eary A+ block
#74 Lplus
Lplus
  • 990 posts
Posted 08 January 2026 - 10:13 AM
Indeed, I see the oilway around the lower bearing shell.  I do have one of those but it's in a car so a bit difficult to check on....  Both my spare blocks are later A+ with the plain lower bearing  - perhaps the cast dish was extended down into the cap with the change in bearing?
#75 Spider
  • 15,684 posts
Posted 08 January 2026 - 04:11 PM
The 'recess or lack there of isn't the issue.
