Hi everyone,
I am a first time engine builder seeking help on a couple of camshaft issues on a 998 rebuild.
1) Adjustable vernier sprocket fouling the triangular retaining plate bolts.
2) 0.3mm of camshaft float.
Pic 1 shows how the sprocket fouls the bolts once it's tightened up. Even with the excess float, I can't see how this setup would clear the bolt heads?
If I use a different duplex sprocket (non-adjustable) the sprocket clears the bolts easily. Am I experiencing a bad design issue?
With the sprocket fitted however, I am getting 0.3mm of float with it all torqued up. How can I remedy this to get it within spec?
Any pointers much appreciated.
