1984.mayfair Wiring Help
12 replies to this topic
#1 Marky998no2
Marky998no2
    Just On Tickover
  • 9 posts
Posted 08 January 2026 - 04:50 PM
Has anyone got a photo of lower lower dash 5 switch plugs wiring connections or what goes where mine differs from manual diagram
#2 lsto
lsto
  • 689 posts
Posted 08 January 2026 - 08:39 PM
I can take some tomorrow afternoon if noone posts before.
#3 Marky998no2
Marky998no2
    Just On Tickover
  • 9 posts
Posted 08 January 2026 - 09:33 PM
Thanks appreciate it
#4 lsto
lsto
  • 689 posts
Posted 10 January 2026 - 05:01 PM
Hi sorry for the delay, I'll be honest I totally forgot. Anyway all terminals are described as if the switches are fitted in the dash and on 2 colour wires the second colour is the trace.
Headlight switch has 2x blue wires to the top terminal, brown to the middle, red to the bottom.
Hazard switch has a green/pink on the top left terminal. Green/white on top right. Green/red on middle left terminal. Dark green/green on middle right which connects to switch illumination. Bottom left is dark green/brown and bottom right is green/brown. Also has a black wire which connects to switch illumination.
Fog light has blue/orange on top. Blue/yellow on bottom. This wire tees off to the switch illumination and there is a black wire to switch illumination.
Heated screen is green/yellow, this tees off to the switch illumination. Bottom wire is green. There is also a black wire to switch illumination.
Brake warning is black/white on top terminal, this also tees off to switch illumination. Bottom wire is black. There is also a purple wire which goes to switch illumination.
I'll try to upload photos but they aren't very good.
#5 lsto
lsto
  • 689 posts
Posted 10 January 2026 - 05:14 PM
Headlamp switch
#6 lsto
lsto
  • 689 posts
Posted 10 January 2026 - 05:15 PM
Hazard switch
#7 lsto
lsto
  • 689 posts
Posted 10 January 2026 - 05:16 PM
Fog light
#8 lsto
lsto
  • 689 posts
Posted 10 January 2026 - 05:17 PM
Heated screen
#9 lsto
lsto
  • 689 posts
Posted 10 January 2026 - 05:18 PM
Brake switch
#10 Marky998no2
Marky998no2
    Just On Tickover
  • 9 posts
Posted 10 January 2026 - 06:18 PM
Thanks that helps ones not working as should hazzards work but not iluminated so if guess bulb,, the brake test one was working& it lights up if put 12vt on side pins but not when fitted to loom, wondered it is linked to inline fuse only got 2both are ok
#11 Marky998no2
Marky998no2
    Just On Tickover
  • 9 posts
Posted 10 January 2026 - 06:27 PM
https://ibb.co/N6QVdcDD
#12 Marky998no2
Marky998no2
    Just On Tickover
  • 9 posts
Posted 10 January 2026 - 06:28 PM
#13 lsto
lsto
  • 689 posts
Posted 10 January 2026 - 07:25 PM
I think there should be 4 inline fuses if I remember correctly. My hazard switch needs a clean up with contact cleaner from time to time because it doesn't work properly sometimes. Really I probably should replace it but I'm tight lol
