Cold Starting
4 replies to this topic
#1 Whizzbang
Whizzbang
  • 68 posts
Posted 26 March 2026 - 10:59 AM
YKG2S2 aussie Mk1 1275 cooper S. Having problems starting when cold and not started for a while. Having to pump throttle for a long time to get started. Once warm no problems. Any ideas? Probably something v. simple that I'm not aware of.
#2 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 26 March 2026 - 11:17 AM
What carb does it have?
What distributor/coil/plugs?
What’s the battery voltage when cranking it cold?
#3 Lplus
Lplus
  • 990 posts
Posted 26 March 2026 - 12:32 PM
Unless you have a weber or equivalent carb, pumping the throttle will not help at all.  The choke system is necessary for rich mixture at starting.
#4 Whizzbang
Whizzbang
  • 68 posts
Posted 29 March 2026 - 09:04 AM
Thanks Lplus and timmy850. I knew it would be easy and should have noticed the fault. Choke knob was jamming and not
fully extending. New one on order.
#5 Ethel
  • 26,580 posts
Posted 29 March 2026 - 11:07 AM
Might be worth checking your engine earth strap. If it's not too good the choke & accelerator cables can get used as supplements
