Leaking Fuel Sender
3 replies to this topic
#1 crbeasley01
crbeasley01
    Starting My Mini Up
  • 3 posts
Posted 12 April 2026 - 07:29 PM
1992 998cc
Hi all.
My prior fuel sender died. I just replaced it and the gasket, but the new one I can’t get to stop leaking. I put some blue gasket dressing on it to try and help, but still no luck. It’s like the retaining clip I can’t set it tight enough, but if I over tighten it then it gets worse and backs off. Ideas?
#2 andyapanel
andyapanel
  • 642 posts
Posted 13 April 2026 - 11:31 AM
How did the old sender feel when you removed it?
I tap on the flanges with a hammer and chisel to tease it back in so it locks positively; doing it by hand will not be tight enough.
I have never used blue gasket sealant on it.
Good luck.
#3 crbeasley01
crbeasley01
    Starting My Mini Up
  • 3 posts
Posted Today, 04:20 PM
Took the tank out to get a better angle and seem to have got it. Tapped the back tab down a little so it would have better leverage on the sender and that seems to have got it to seat well.
#4 Spider
  • 15,685 posts
Posted Today, 05:40 PM
I've only ever fitted up the seals on these 'dry', just clean the faces. I'm guessing here the sealant was slippery and possibly allowed the seal to dislodge.
