Stuck Rear Trumpet In Rubber Cone — 1976 Mini
11 replies to this topic
#1 twinding
twinding
    Just On Tickover
  • 5 posts
Posted 04 May 2026 - 06:10 PM
Hi
I'm restoring a 1976 Mini and have the rear subframe off the car. I need to separate the aluminium rear trumpet from the old rubber cone spring so I can clean up the trumpet. it seems that they are stuck together.
What's the best approach?
Any advice appreciated.
#2 mab01uk
mab01uk
  • 12,914 posts
Posted 04 May 2026 - 06:32 PM
Some ideas in this video which may help....
Separating the suspension trumpet from the rubber cone:-
#3 Quinlan minor
Quinlan minor
  • 1,321 posts
Posted 04 May 2026 - 06:36 PM
Beaten to it.
Edited by Quinlan minor, 04 May 2026 - 06:51 PM.
#4 twinding
twinding
    Just On Tickover
  • 5 posts
Posted 05 May 2026 - 08:10 AM
Are the parts glued together?
#5 Quinlan minor
Quinlan minor
  • 1,321 posts
Posted 05 May 2026 - 08:21 AM
Not intentionally, but road dirt and corrosion is an effective substitute.
#6 mbolt998
mbolt998
  • 433 posts
Posted 05 May 2026 - 08:34 AM
Blow torch and hammer (and be prepared to roll it around on the grass when it catches fire). This way you can save the trumpet. I assume you're replacing the cone. If the metal bit in the middle of the cone sticks to the trumpet rather that coming off with the cone (as it did in my case), weld a bit of square tube onto it and then bash that to get it off.
#7 stuart bowes
stuart bowes
  • 2,525 posts
Posted 05 May 2026 - 08:40 AM
honestly, I gave up and thew mine out
a cleaner nicer looking set of replacement trumpets with the rubbers removed were on ebay for about £15-20 plus shipping
and then I bought adjustable anyway which you might also consider maybe, if nothing else a LOT easier to fit
by the way if anyone near me needs a set let me know, they're sitting unused in my shed (sorry I don't want to get into international shipping)
Edited by stuart bowes, 05 May 2026 - 08:43 AM.
#8 Designer
Designer
  • 733 posts
  • Local Club: LSMOC
Posted 05 May 2026 - 11:30 AM
Hi,
I would like to point out that Plus Gas is much better than WD40 for freeing off jammed parts.
Paddy
#9 Ethel
  • 26,568 posts
Posted 05 May 2026 - 12:14 PM
There's a steel seat inside the rubber that causes the aluminium to corrode. You can tap & twist the trumpet against that seat but you may end up having to choose one or the other to sacrifice.
#10 twinding
twinding
    Just On Tickover
  • 5 posts
Posted 06 May 2026 - 05:38 PM
Maybe my English hasn't been entirely correct here. I am talking about the rear end of the car. I have been trying to get the 2 parts split the last 2 evenings without any luck yet. It is completely loose on the sides, but still I cannot get them apart. Isn't that strange?
#11 Quinlan minor
Quinlan minor
  • 1,321 posts
Posted 06 May 2026 - 05:53 PM
Sadly, no.
As in the YouTube video, it may take quite some time.
If Minis had been around, back then, it would have been one of the labours of Hercules.
#12 Gaz66
Gaz66
  • 1,146 posts
Posted 06 May 2026 - 10:16 PM
Ive never separated these without destroying the rubber donut.
Budget in two new donuts 👍
