I have a Mini Mayfair 1275 from 1996. It's injection, and has an immobiliser.
I've been driving it for a few months now, and this is the first time this problem has happened.
I was driving it yesterday, stopped somewhere, got back in a few minutes later, and it wouldn't start at all.
When you turn the key, there is definately a click somewhere from under the bonnet, so the ignition is apparently at least connected to whatever system it connects to.
I figured out straight away yesterday that it bump starts fine (that's how I got home).
Today I had a friend round trying to help me, and we accidently discovered that if you cross over the bolt in the middle (with a few wires coming off it) of the starter motor, with the spade connector at the edge (with one wire coming off it), you get a lot of sparks, but more importantly the starter motor turns and the car starts easily (assuming ignition is turned).
So I put it to you - what is the problem here?
Please bear in mind that I'm a bit of a dummy when it comes to cars, but I'm trying to learn. So I can try whatever you suggest, but it might need some explaining!
Edited by l_bratch, 27 November 2006 - 10:20 PM.
