Heating Up! how do you test the fan???
Posted 30 November 2006 - 10:11 PM
Posted 30 November 2006 - 10:13 PM
unless you mean the wing mounted thermostatic one fitted to later minis?
is your thermostat in the head opening?
Posted 30 November 2006 - 10:16 PM
The fan on the radiatorif the engine is running the fan is turning!!!
Posted 30 November 2006 - 10:18 PM
Posted 30 November 2006 - 10:20 PM
Its a Mayfair 998cc engine and is a 1986jack what year and engine is your car?
Posted 30 November 2006 - 10:21 PM
Engine side or wheel side of the radiator?
Posted 30 November 2006 - 10:24 PM
if it is attached to t he engine and it goes round when th ecar is runnung then it aint a fan problem
Your fan is attached to the engine. When the engine is running, the fan is turning.
I would suggest you check your water level.
Check the level, if need topping up, add enough so it comes just about the fins as u look into the cap.
Leave the cap off and run the engine. Let the engine run for about 15-20mins and keep an eye on the temp guage. When the temp reachs normal, check the water level.
By leaving the cap off, this allows any trapped air to circulate and escape at this point. Touch the hoses and make sure each hose is getting warm, there may be a blockage somewhere if not.
If the water level as dropped as the air as escaped. Top up as required. NOTE.....dont pour cold water/coolant straight into the hot engine/radiator. Its best to let it cool down first.
DONT FORGET TO REPLACE THE CAP!!!!!
Then give it another try, if its better then bingo.
If not, come back and report to us and we'll suggest more you can try such as thermostat.
Edited by Jordie, 30 November 2006 - 10:25 PM.
Posted 30 November 2006 - 10:26 PM
Engine side.
I take it this isn't common then?
Posted 30 November 2006 - 10:27 PM
Posted 30 November 2006 - 10:28 PM
My diesel mondeo was always a big when changing coolant, would take, what seemed a decade to work the air out of that.
Posted 30 November 2006 - 10:32 PM
I mean that the guage doesn't go up and down on all minis like this.what isn't common?
I did notice the first time when I said it went into the red there was no water left in the rad, So I topped up and it doesn't seem to have gone down since doing it but I will try running as said with the cap off and see what happens.
So basically the fan which is on the rad should be spining when the engine is running at all times yeah?
Posted 30 November 2006 - 10:34 PM
just to help with any confusion.
And by running. I mean ENGINE IDLING. not been driven. Never drive the car with the rad cap off, or you will loose all your fluid and overheat.
Posted 30 November 2006 - 10:38 PM
