Dutch HayaMini project
#31
Posted 13 October 2007 - 02:09 AM
if you carry on adding anymore weight it will be very slow aswell
#32
Posted 13 October 2007 - 06:40 AM
#33
Posted 13 October 2007 - 09:38 PM
#34
Posted 14 October 2007 - 07:58 AM
good progress but trust me you wont need power steering.
I know he's going to be running on 15 inch wheels. maybe that's why he is installing the power steering....
Het won't be any slower with some extra weight either.... At least not afther his turbo/compressor added!
#35
Posted 14 October 2007 - 08:38 AM
Hey Custom Minis, which provider do you use? I had a lot of problems with spam text about pills and lots of other unwanted text as comment on the photoalbum and since then I blocked some global addresses. The biggest one is RR.com (Road Runner high speed online) which is hosting internet in the States.Anybody else having problems accessing the web site?
Please send me an PM with some info so I can check it out to let you access the website.
Patrick.
#36
Posted 14 October 2007 - 08:47 AM
You do not need an Oxy burner for lead loading. You only need low temps and nothing that get above 500 degrees Celcius.
@Mark & Renessy:
Renessy is right. The mini will be running on 15" wheels with 195/45 or even 215/40 tires, then steering can get heavy with these tires. And the big supprise is that I am going to build a compressor on the busa engine so then it will have lots of torque and BHPs.
#37
Posted 15 October 2007 - 08:51 AM
#38
Posted 16 October 2007 - 07:05 AM
Interesting you say that Poly Potje. I bought a lead loading kit from Frost Restoration, but thought I need Oxy stuff. Is that Propane or Butane?
Hey Jammy, that does not make a difference if you use propane or butane.
Using butane when the temperature is below 0 °C, then there will not be any gas because the boiling point of butane is at -0.5 °C and then it vaporizes. The boiling temp of propane is at -42 °C and that makes it usable when it is freezing. The second thing is gas pressure. When the environment temp is at 15 °C, then propane will be at 6.5 bar and butane 1.7 bar.
With these things in mind you can make a choice. If you are working in an environment with normal temperature conditions (above 0 °C), then you can use butane. The second thing you have to look at is the amount of heat you need for your job. The amount of mixed air/gas will produce a certain amount of heat and when there is more pressure and you use a high temp torch, more fuel can be used that result in higher temps.
Here in the Netherlands, these small gas burners are supplied with propane bottles. I experienced when shaking the bottle, the flame gets uncontrollable because more liquid propane will evaporate. For lead loading large areas the easiest way is using a large camping bottle and a hand torch. For small areas a small burner will be ok.
For lead loading, you do not need high temps so I think that butane can be used as well.
#39
Posted 15 August 2008 - 07:16 AM
The arches are hand made from 1mm steel plate (this was a bit difficult, even to make both sides for front and rear identical),
normal_IMG_2213.jpg 29.77K 107 downloads
Added the TTS dry-sump system to the busa engine.
normal_IMG_2305.jpg 30.86K 57 downloads
Made some adapter/spacers and change the bolt-pattern from 4x4" to 4x100mm (front is 48mm and rear is 52mm).
normal_IMG_2366.jpg 19.19K 53 downloads
Made my own wiring-loom from scratch. There was no fault in it and the engine started directly after turning the key.
normal_IMG_2378.jpg 28.17K 25 downloads
Added full stainless Goodridge oil-lines with thermostat and oil-catch can.
normal_IMG_2411.jpg 32.1K 57 downloads normal_IMG_2412.jpg 29.48K 26 downloads
Meanwhile a stainless 2.5" exhaust system is made. The header had to wait because there was no money left. I do not want to spoil it by going for less quality. Because of the regulations it must have a cat. So I added a 400cpi metalcat (race cat) to do the job, this one is made for at least 300hp).
normal_IMG_2429.jpg 30.31K 28 downloads normal_IMG_2456.jpg 27.59K 77 downloads
Ok, now just some eye-candy. Replace all black hoses for nice looking blue vac. hoses.
normal_IMG_2470.jpg 35.69K 43 downloads
Added a simple removable frame in the rear the make a bit stiffer.
normal_IMG_2907.jpg 29.46K 72 downloads
Now I am making slow process because I am waiting for the rotors and brackets to fit my Subaru Impreza WRX 6-pot calipers.
normal_IMG_2926.jpg 24.51K 33 downloads normal_IMG_2936.jpg 23.86K 44 downloads
normal_IMG_2937.jpg 23.29K 26 downloads normal_IMG_2945.jpg 24.37K 22 downloads
normal_IMG_2948.jpg 22.98K 25 downloads
#40
Posted 29 September 2008 - 09:52 AM
I have done lead-loading on the front arches, the solid Mini grill is put into place and finished and the fibreglass bootlid is modified to fit properly.
normal_IMG_4137.jpg 15.38K 28 downloads normal_IMG_4176.jpg 20.34K 20 downloads
normal_IMG_4234.jpg 30.47K 20 downloads normal_IMG_4235.jpg 30.55K 29 downloads
Next project is finding a way to fasten the bonnet and bootlid without anything on the outside, so it gets a smooth finish. I also want some kind of hinges on the inside and locks to keep the bonnet and/or bootlid a bit open to let the hot air out when needed. Upto now I have not found a proper solution.
Edited by Poly_Patje, 29 September 2008 - 09:53 AM.
#41
Posted 29 September 2008 - 10:14 AM
#42
Posted 03 May 2009 - 11:08 PM
After not using the engine for 362 days, it fired up without any problems!
Click here for hearing the engine start (divx movie).
Next things to do before taking her out for a spin are:
- finishing bulkhead;
- making the dashboard;
- putting the seats and belts back in;
- bleeding the brakes;
- putting the chain on.....
#43
Posted 04 May 2009 - 08:39 AM
After working too many hours on the project, the car finally started last week.
do you also have some new pics
Jaapio
#44
Posted 05 May 2009 - 06:47 PM
I think I was one of the first to hear that you had your mini running..... Awesome! Just awesome!
Hope you can get it on the road fast so we can go for a spin.
Congrats and see you soon!
René
Now I really have to hustle to get mine running soon....
#45
Posted 17 July 2009 - 09:41 PM
This is an image of the current situation:
IMG_5367.jpg 592.73K 62 downloads
What is left to be finished:
- Covering complete bulkhead with isolation material;
- Modifying the loom near the ECU in such way, that I am able to reprogram the ECU for using a turbo;
- Redesigning steering because there is to much 'free' movement without any response to the wheels when driving;
- Adding all self-made devices for measuring every engine condition (temps, speed, etc) for tuning and logging;
- Finishing the dashboard in carbon fiber;
- The last thing is putting the rear and side windows in and closing the mini...
So, it looks like a short list, but time is needed to fully finish it. After finishing I can go the dutch RDW again for getting it 'street-legal'.
