Dutch HayaMini project
#46
Posted 17 May 2010 - 01:23 PM
The last 6 months I have been working on building a GT35r on the busa. It runs nicely on 4psi basic boost and can go to 32psi.
For now I am not able to upload the picture with the following message: "Upload failed. Please ask the administrator to ensure the uploads directory is writeable".
#47
Posted 17 May 2010 - 01:36 PM
#48
Posted 17 May 2010 - 02:18 PM
The Mini is nearing completion and I hope to finish it the next month. Then I will go to out for a dyno for the final adjustment. I have not used any other ECU, but I have altered the 32-bit ECU with success. I know one thing for sure, and that is when boosting above 6 psi it is very difficult to handle when the boost increase too fast.
Edited by Poly_Patje, 17 May 2010 - 02:27 PM.
#49
Posted 20 May 2010 - 11:59 AM
I also would like to see a dyno, hopefully on a dyno like the one JD Engineering has.
#50
Posted 21 May 2010 - 08:56 AM
Top nieuws dat het lekker opschiet! Very interested in the pictures, i will drop by very shortly.
cheers.
#51
Posted 25 May 2010 - 10:47 PM
IMG_5619.JPG 116.81K 21 downloads
IMG_5692.JPG 126.27K 70 downloads
On the right side of the engine you see the new oil tank for the drysump system. I had to make room for the 3" exhaust pipe coming out the GT35 and the Tial wastegate. The previous tank was good for 5 liters of oil, the new one can hold at least 8 liters and even then it is 2/3 full. So it can even hld more oil but then it would be expensive when changing it.... I made all the parts like header, tank, downpipes, intakepipes and all the needed flanges for the header, turbo and wastegate.
#52
Posted 25 May 2010 - 10:56 PM
#53
Posted 29 May 2010 - 09:57 PM
Today I have put the bulkhead and seats back in. Too bad that is started raining at 1700 and it did not stop, otherwise I took her out for a drive. But during the evening I pushed her out and washed her during the rain and took some pictures too. So I have 2 nice pictures for all of you. Comments are always welcome
IMG_5714__1024x768_.JPG 122.99K 77 downloads
IMG_5719__1024x768_.JPG 141.2K 77 downloads
#54
Posted 29 May 2010 - 11:30 PM
#55
Posted 30 May 2010 - 02:43 PM
Mini looks great. Can't wait to see how it goes and handels with that extra power!
#56
Posted 30 May 2010 - 03:12 PM
Thanks! The arches are all made smooth with the good old trick of lead-loading and no fiberglass or much filler is used.Wow its looks great! - The way the rear arches flow onto that custom valance with the vents. Also every mini photo with a mini with wheels larger then 13" i have never like due to them looking way too big for the body of the car BUT your car is an exeption - Maybe because it is nicely lowered ? (rhetorical question)
The wheels are 15" because of the 296mm discs in the front with huge Subaru Impreza 6-pot caliper (made for the rally-sport). The lowest point on the front has 6cm clearance and the lowest point on the rear has 5.5cm clearance.
That is pretty low, but high enough to drive over the usual speedbumps.
#57
Posted 01 June 2010 - 01:07 PM
by the way 300BHP in that is going to be awesome.
Enjoy it to the full.
