timing all ballsed. help appreciated
Posted 12 December 2006 - 11:48 PM
better change that. used the strobe couldnt get it right for ages, of course that was because i forgot to take off the vac pipe.
what should my timing be on a 1989 998? 8 or 10 degrees? i dont have a rev counter. i'm supposed to set it to 1500 rpm? i have no way of doing this, can anyone explain a good way of doing it without a rev counter.
what should i be listening out for?
and i am a tard, but what is pinking? whats it sound like? if i tarded the timing the engine just bogged and there was a huge flat spot. advancing it got better but then the ide went up loads. plus i didnt want to advance it too much as i didnt know if its bad for the engine.
took it for a drive and my exhaust popped, this is cause of the leak at the manifold though. never done it before. the engine sounds different now, almost like its louder, especially the induction roar because i have a cone filter.
if my foot is flat on the floor it nearly deafans me. is this because of the thinner oil or to do with the timing?
i'm tempted to change the oil back but want to keep it.
anyway, i have searched so if anyone could answer my questions i would be very appreciative.
just a retards guide to doing it all properly should be good, and what to listen out for.
and my head unit has decided to give up on me, approx 1 month after the warranty run out, so anyone know anything about dead hu's please look in the ice section.
thank you all very much,
Stef
Posted 13 December 2006 - 01:21 AM
i have seen a 998 engine running fine at 30deg advance at tickoverwithout vac pipe! and it made 49bhp at the wheels! if it wasnt making a pinkiing noise then put it all back to ehere it was!! going with the rule if it aint broke then dont fix it!!
Posted 13 December 2006 - 01:32 AM
then set the idle, then re check?
was me that did it before, then fiddled with the idle so the advance shot up.
i know it wasnt perfect before, worse now though!
and i have to do it at 1500 rpm, or just a fast idle? like when i pull the choke out in the morning for a few mins?
edit: for the pinking u say loaded, is that when driving or just rev up the engine?
Edited by stef, 13 December 2006 - 01:34 AM.
Posted 13 December 2006 - 01:38 AM
a free rev out of gear is not loading the engine at all really!!
Posted 13 December 2006 - 01:44 AM
ok cool, think i may have heard it earlier when i was setting it up.
so its ok to set it as advanced as i want as long as theres no pinking?
and a fast idle is ok yes?
cheers dude,
Stef
Posted 13 December 2006 - 01:47 AM
Posted 13 December 2006 - 02:06 AM
i really should contribute more, but i usually get it wrong
cheers mate
Posted 13 December 2006 - 02:07 AM
Edited by fikus01, 13 December 2006 - 02:08 AM.
Posted 13 December 2006 - 11:26 AM
Posted 13 December 2006 - 03:05 PM
(snip) i dont have a rev counter. i'm supposed to set it to 1500 rpm? i have no way of doing this, can anyone explain a good way of doing it without a rev counter.
(snip)
If you get yourself a decent multimeter (still no need to pay more than about 20 quid though) - it'll have an RPM function. You hook it up to the coil, and then not only do you have a revcounter, but it's under the bonnet with you so you don't need a rubber neck! Look for one with a dwell function too, and you can set your points with it as well.
Posted 13 December 2006 - 03:39 PM
(snip)
Any recomendations for a multimeter, I had a great one years ago but they all seem to be digital now and the numbers jump about so much it is virtually worthless!!
Posted 13 December 2006 - 05:32 PM
3-1 alone would be thick enough to get the smooth response you want.
I've always used 3-in-1 worked great for me.
Posted 13 December 2006 - 09:27 PM
Posted 13 December 2006 - 09:59 PM
UT105 Automotive Multimeter cost just over 26 notes
Just connect the little clips, one to the coil and one to ground, set the meter to the rmp setting and switch it on.
Posted 14 December 2006 - 01:40 AM
anywho did my timing again today, running much better now, bout as advanced as i can get it because the idle is too high otherwise.
am going to change my oil back though, or run a mix of both.
and the guys at the shop said they mighjt be able to fix my hu under warranty even tho its not. so thats good =)
happy day today.
