Remote change shell/rod change box
10 replies to this topic
#1 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 13 December 2006 - 10:50 AM
I have a semi-technical question:
If I were to convert my '71 MKIII shell to accept a rod-change box, would I have to cut so much of the tunnel away that I would never be able to change it back? I am considering doing this so that I can fit my A+ SCCR 'box into the shell, but obviously that is rod change.
What other options do I have? Could I use the A+ internals inside the remote change 'box? Is the casing up to the job? I will be running IRO 100 donkies and hopefuly a bucketfull of torque through this 'box and also the rubber couplings.
Basically, how much modifying is required to fit the rod change doofah? Would it be lessened if I were to fit a couple of UJ's to the rod change and fit the gearshift higher up, inside the vehicle?
EDIT: Actually, the tunnel appears flatter than a later rod change one, perhaps this would leave the base of the gear change unit too low? Maybe it's best all around if I try to rig it all up internally as I suggested above.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 December 2006 - 10:59 AM
I expect the easiest think to do is replace the tunnel from a later model mini....
I think webweavers may be able to help there as he has a 30 which I believe is being cut up.
Never realy had a close inspection...
As for putting the internals into a remote, yes it's possible, but the reverse idler would need to be changed, as would your idler gear in the drops, both of which would be dependant on availability...
#3 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 13 December 2006 - 11:02 AM
i reckon doing an internal onversion would be the simplest and quickest way
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
or see if jimp still has that remote set for sale.... http://www.theminifo...showtopic=36339
#5 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 13 December 2006 - 11:03 AM
Hmmm, cheers for that John. I will have to have a serious think about it. I could use the tunnel from a scrap shell that I have at my mum's house (must move it soon) :gimme:
I might cut the tunnel from the scrap shell anyway, so I can use it as a pattern to compare the two setups. Then I can see just how different they are. :D
#6 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 13 December 2006 - 09:41 PM
the remote is much bigger than the rods so i think no mods are needed to the tunnel
in fact i am almost 100% sure (apart from drilling new holes for the rod box)
#7 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 14 December 2006 - 01:19 AM
minispares used to sell and believe they still sell a converttion plate to hod rod change in remote tunnel wih no cutting
dave
#8 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 14 December 2006 - 09:00 AM
dave
Dave, you are a legend!
*Matt runs off to the Minispares site*
#9 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 14 December 2006 - 12:56 PM
But the remote is mounted in a totally different place (off to the left, rather than tunnel centre). :D
#10 miniboo
miniboo
  • 9,327 posts
Posted 14 December 2006 - 01:00 PM
have you found a conversion plate? i reckon there must be some cutting for the hole but apart from that it shoulod fit in the tunnel ok
#11 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 14 December 2006 - 02:16 PM
Not yet, dunno if they exist yet :D
EDIT: Just gonna take some paper and make a template off the MKV tunnel and overlay it on the NKIII to see how it compares. If it's only a case of drilling 4 bolt holes and enlarging the cutout then that's not a major problem really.
