RPM
Posted 13 December 2006 - 10:02 PM
Sorry for being a n00b
Posted 13 December 2006 - 10:05 PM
Posted 13 December 2006 - 10:32 PM
although I normally shift at 5000rpm.
Posted 13 December 2006 - 10:40 PM
Posted 13 December 2006 - 11:19 PM
Posted 14 December 2006 - 02:19 PM
Posted 14 December 2006 - 02:21 PM
Posted 14 December 2006 - 08:06 PM
the old rover mini manual that comes with the car tells you that under normal driving conditions you should keep the revs between 2000 and 5000 rpm!! full acfceleration isnt normal driving conditions, most rolling roads will test power to 6000rpm unless you state otherwise!! a std 998 bottom end is perfectly happy coping upto 7000rpm before you have to worry about big end bolts!! 1098's arent as rev happy tho but the longer strokd does make them torquey!! stil mine is happy to pull to 6000rpm with a kent 256 cam!!
Posted 14 December 2006 - 08:35 PM
Posted 14 December 2006 - 10:32 PM
especially 970 and 1071 lumps:D try 10'000rpm
Posted 15 December 2006 - 12:10 PM
2500 - 3000 rpm!! shes only making half power at that point!! serously if it goes bang at 5000rpm it was guna go bang neway!! and a std bottom end on a 1098 is good for 6500 trust me mine is std and does it regularly! if there is no power there then dont push it. i know minis are noisy but they do have some revs in them!!
You make a good point there, you should'nt drive because your worried your car will go bang, otherwise you wont enjoy it. Now ive finally sorted out all (most) of my minis running problems im going to start really driving it again, and i can take roundabouts at speed again now ive fixed the CV joint which has been clicking for the last 3K.
Posted 15 December 2006 - 12:15 PM
Posted 15 December 2006 - 02:29 PM
im thinking of trying one with a 74mm bore and 7 port head for future developments!! shud nearly make 1300cc!! but will rev like a bike!!
Posted 15 December 2006 - 02:36 PM
IIRC mine hits top BHP at 5290 and torque is about 3700 (will check that when I get back!). I always shift just after peak BHP and it seems to work pretty well
When you do the shifting action, is the aim to shift so that the revs drop down above or below where the peak torque is produced ?
Posted 15 December 2006 - 02:43 PM
and peak power on my 1098 really is over 6000rpm!! trust me if ther was no power up thre i wudnt take her there!! im well aware some chav style racers have to wait for the max revs or rev limiter before a gear change but thats not what i do!! jsut want to get max power and then go!!
by all rights my racer shud pull to nearly 7000rpm!! and its only got a 276 cam!!
