MG METRO GEARBOX HELP
12 replies to this topic
#1 ROD
ROD
  • 2,215 posts
  • Local Club: MCR
Posted 15 December 2006 - 07:10 PM
My mini has a MG metro engine and box in it, but the box whines in first and second,i've been offered a box from a 998cc mini
(91/h reg) are they the same???
ROD :gimme:
#2 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 15 December 2006 - 07:14 PM
yep but the final drive may be different
also how much have you ben offered it for? do you know the condition? it may be better getting a 50 quid refurb box from guessworks it will have the right diff for defo then aswell
Edited by miniboo, 15 December 2006 - 07:15 PM.
#3 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 15 December 2006 - 07:55 PM
I imagine the MG Metro will probably be 3.44 whilst the Mini will be 3.1?
#4 ROD
ROD
  • 2,215 posts
  • Local Club: MCR
Posted 16 December 2006 - 01:03 AM
Do you have some contact details for guessworks?? (sorry i'm new to minis)
#5 miniboo
miniboo
  • 9,327 posts
Posted 16 December 2006 - 10:07 AM
yep do a search on here for guessworks.
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 December 2006 - 11:28 AM
Hmm, 998 H reg. Could be from a Racing/Flame/Checkmate. If it is then it has a 3.44 diff and I think is exactly the same as the MG Metro box. There may be a difference in one of the bearings. Ask Guessworks, he knows all about gearboxes.
#7 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 16 December 2006 - 09:28 PM
Oh yes I forgot about them. :D
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 December 2006 - 12:40 AM
only the MG turbo had a different bearing, and that's the nose bearing on the input so no biggie.. other than that, no different to any other A+ box.
#9 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 17 December 2006 - 05:42 PM
hello gw just curious but i have a turbo gearbox with the larger bearing as stted above but its not drilled for metro mounts!! did they fit mini era's with a mini flywheel housing?? im suspecting i could have a genuine era 'box!!
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 December 2006 - 09:20 PM
I assume you're talking about the transfer case and not the box, as there are no mounts off the box itself, metro or mini..
#11 fikus01
fikus01
  • 1,910 posts
Posted 18 December 2006 - 12:35 AM
yeah thats what i meant :D on the back of the transfer case there is a 3 bolt mount for a metro and at the front there is another metro mount that bolts on just round the starter motor!
mine has neither
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 December 2006 - 08:57 AM
The it's a pre A+ transfer case, which has probably been machined out ( you'll find it has a 12G casting number somewhere ) what size is the idler bearing ?
#13 fikus01
fikus01
  • 1,910 posts
Posted 19 December 2006 - 02:20 AM
:D bigger than a+ thats all i know!! i discovered it when trying to use the housing on something else and realising it wouldnt fit! unfortunately its in my car at the mo so i wont be taking it out again til i get another car!!
