What type of primer for bare steel?
Posted 22 December 2006 - 01:20 PM
For my Mk1 Cooper, I have just had the grill panel plug welded to the bonnet catch panel, as some of the spotwelds came apert. the surfaces are now ready for priming and painting. (I will first however use paint prep to clean the surfaces thoroughly.
The surfaces have been runned down so than there are some painted areas still present, but this has been feathered in to the bare steel surfaces.
My question is about primers. What is the best type of primer to use on the bare steel? I already have self etch primer in aerosol, but do you recommend I use an alternative like red oxide, or zinc primer?
Posted 23 December 2006 - 01:16 PM
Hi All
Nah mate, just use the etch, then go over it with 2k (2 pack) primer. This is what is done in the trade and it is perfectly sufficient. You don't want to cover it with too many different types of primers as this makes chemical reaction more likely. When you spray the etch, dust it on very thinly. You don't need full coats, this will more than likely cause reactions on the feathered edges, plus it will take forever to dry.
Posted 23 December 2006 - 04:09 PM
then use green ti primer i say
then dust on some black
wet flat it back and u will see if its perfect or not
Posted 05 January 2007 - 11:28 PM
I will wait for a couple of weeks before I feather in the edges to the rest of the paint, with some 1200 Wet or Dry and T-Cut, then assemble the bonnet latch mechanism back in position.
I am well pleased the way its turned out, the paint finish has a smooth and high lustre.
For the coatings, my first coat was Hammerite Rust beater,then primers, and lastly the colour top coats.
Thanks for your help
Edited by mk=john, 05 January 2007 - 11:29 PM.
