whilst my rear subframe was off i had new plates welded in to cover holes and rust then fitted a newer subframe and radius arms along with mini spares adjustable rear camber brackets.
the camber brackets where a nightmare and needed bending and the holes elongated in order to fit.
now the N/S (passenger side) rear wheel pokes out an inch or so further than the O/S rear wheel.
Any ideas why this is? will it be because of the camber brackets? or is the subframe maybe not on right? Plates where added to where the subframe bolts to the N/S boot floor but welded over the origional panels once rust cut out so the bolts where fitted in the same place.
thanks for looking
Daniel
rear wheels/subframe misaligned?
daniel_johno
, Dec 27 2006 11:39 AM
2 replies to this topic
