ive got a cooper S setup that i reconing. but they dont have any steering arms.
but ive got an old set of '84 disc setups (8.4") with steering arms on. will these fit on an S setup?
i am a bit confused because on the minisport web site thay have a set especially for "cooper s" but is that the car or the setup, im not sure?
thanks
steering arms
JoeBodge
, Dec 29 2006 03:57 PM
4 replies to this topic
Posted 29 December 2006 - 03:57 PM
Posted 29 December 2006 - 04:26 PM
Same geometry but the 'S' arms are of meatier meat.
Posted 29 December 2006 - 04:27 PM
You can use the standard steering arms from the 8.4" setup.
The S arms are much beefier.
I used to have the std ones and they bent when I hit a kerb in the Alps - Now got the S ones on instead. However, be careful. As the S ones are much stronger, if you clout a kerb or anything the forces will probably break something more important as they wont bend so easily.
Posted 30 December 2006 - 12:06 AM
ahh cheers, will use the standard ones, saves on the pennies at the moment.
thanks
thanks
Posted 30 December 2006 - 11:14 AM
S ones are indeed a lot thicker and so stronger but they also have less metal on the outside where the disc runs. The standard ones can sometimes touch the disc here, especially if there is less than the minimum run out of the disc as the S disc is closer to the hub than the 8.4" disc. Each arm is different though so you can't be sure what is and isn't a good fit without trying it. Standard arms are fine on mine but some people have problems.
