mk1 style switch panel for mk3 dash.
4 replies to this topic
#1 daniel_johno
daniel_johno
  • 310 posts
  • Local Club: AMOC
Posted 29 December 2006 - 07:13 PM
i removed the lower padded dash rail on my mk3 to go for the mk1 look. Ordered a mk1 switch panel thinking it would fit in the hole only realise the panel is too small!!!! grrrr
Do any companies make a bigger switch panel so it can be fitted like on the mk1? or do i need to try make my own?
Thanks for looking
Daniel
#2 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 30 December 2006 - 02:26 PM
er its supposed to go on the outside!!
#3 bert998
bert998
  • 2,558 posts
Posted 30 December 2006 - 06:55 PM
Its meant to be housed in the lower dash rail (the padded bit), not behind the rail :D
#4 knoxie21
knoxie21
  • 92 posts
Posted 30 December 2006 - 07:19 PM
M-machine do a conversion panel which is welded into the existing hole allowing you to fit the mk1 switch panel
http://www.m-machine.....ch Panels.htm
part no. 11.71.04.05
#5 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 30 December 2006 - 08:27 PM
yes the Mk1 panel should look like this (behind the rail)...
but late vans and pick-ups had these ones...
i suggest you get someone who is good at welding, fill the hole over and then re-cut to suit the new panel or use the adapter plate mentioned above
Edited by THE ANORAK, 30 December 2006 - 08:28 PM.
