Up grading brakes
23 replies to this topic
#1 mulejones
mulejones
  • 158 posts
  • Local Club: mini diddlers, of retford
Posted 30 December 2006 - 04:14 PM
Im looking to upgrade my brakes, with out spending an arm and a leg, but i have no idea where to start. At the minute im just runnig the standard disks and pads.
Any suggestions will be helpful
thanks
#2 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
  • Local Club: fabmoc/TMF
Posted 30 December 2006 - 04:24 PM
Get some drilled and groved disk's and fast road pads like mintex or greenstuff
#3 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 30 December 2006 - 04:26 PM
mintex pads + shoes are very good and once bedded in are lovely even when caned! not sure about disks, I suppose you could get vented discs but i don't see the need for them on a road car.
Green stuff are meant to be good when warm...
#4 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
Posted 30 December 2006 - 04:37 PM
links
Disks
Pads
Hope this helps
#5 robson
robson
  • 798 posts
Posted 30 December 2006 - 06:59 PM
if you are feeling adventurous, you could fit some metro 4 pot calipers which wont cost too much (second hand) and will be noticeably better
#6 minipip
minipip
  • 1,591 posts
  • Local Club: TMF SE
Posted 30 December 2006 - 08:43 PM
i would say dont get drilled discs as they are weaker between the holes and tend to crack, just go for groved ones, and yes 4-pots thats prob the best you could go for on a road car, but if u want to go full with an arm and a leg and mabie a lung too go vented.
#7 stickycreambun
stickycreambun
  • 1,865 posts
Posted 31 December 2006 - 12:04 PM
also maybe want to consider braided hoses, mainly just improves the 'feel' of the brakes a bit. oh and i presume you have rear drums, could think about new shoes to and maybe some minifins.
#8 ROD
ROD
  • 2,215 posts
  • Local Club: MCR
Posted 31 December 2006 - 07:54 PM
why are minifins better???
#9 Big_Adam
Big_Adam
  • 7,435 posts
Posted 31 December 2006 - 08:31 PM
good for heat dissipation.
#10 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 01 January 2007 - 06:01 PM
lots lighter!!
#11 mulejones
mulejones
  • 158 posts
Posted 01 January 2007 - 07:58 PM
Cheers guys, i think i will have a look at the show coming up and talk to some guys, but thanks for the advice, its given me somthing to think about!
#12 Dev
Dev
    Fiat 500 'Ringer
  • 1,549 posts
  • Local Club: NF500
Posted 01 January 2007 - 08:34 PM
If you can get mintex or ferodo, avoid greenstuff as quality varies between batches although you do get a free sticker.....
seriously you cannot fault mintex. drilled and grooved are good but slightly weaker than just grooved in construction. to be fair though they look cool.
minisport do a sure stop kit which is good value for the 8.4" set up.
dev
#13 Bass Man
Bass Man
  • 321 posts
  • Local Club: London & Surrey MOC
Posted 03 January 2007 - 02:53 PM
Has anyone ever fitted a brake servo to a non servo drum/drum system? Just a thought..... :w00t:
#14 Jammy
Jammy
  • 25,397 posts
Posted 03 January 2007 - 03:12 PM
A brake servo won't give you anymore braking power.
In the two and a half years I've been on TMF I don't believe anyone has ever come on the forum complaining that their drilled discs have cracked. Not saying it doesn't or couldn't happen, just that I've seen a hell of a lot of problems in the Technical section, and I don't recall any of them being this problem. I certainly wouldn't of thought it would be a problem with good quality discs.
#15 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 03 January 2007 - 03:15 PM
Agree with Jammy on this, its highly unlikely to happen and would take some serious force which IMO you couldnt apply with the brake calipers on their own. Brake manufacturers do some pretty rigorous testing on their products to make sure that this type of thing doesnt occur.
