Will i need a SVA?
Posted 12 September 2004 - 02:12 PM
I want to use a new fibre glass shell to start the project and fit a Z-CARS R1 kit into the back.
most off the parts will be recon/new and i will use donor mini for some of the small bits'n'pieces.(not many parts will be need from the donor)
The problem being is that hardly any of the finished mini will be from the donor mini.
Could i get around an SVA buy saying i reshelled the original mini using a GRP shell (chop up and scrap the old shell), then did the bike conversion or would this be pushing my luck a bit too far, any suggestions.
I need some advise as to what the mini would be classed as, i rather it didnt have a Q plate.
if anyone has done something similar your comments are very welcome.
Ian.
Posted 13 September 2004 - 09:48 AM
http://www.dvla.gov....es/regrebil.htm
I'll leave the answer upto you own interpretation....
but whats wrong with a "Q" anyway, unless you're trying to reshell a pre 73 car and diddle Mr Road tax.
Posted 13 September 2004 - 09:57 PM
Posted 13 September 2004 - 10:13 PM
BUT LUCKILY
You don't get a Q if you take an SVA, you get registered as a brand new car. And therefore you dont need an MOT for three years either.
Posted 13 September 2004 - 11:00 PM
I think i might go over budjet if i have to buy everything new and have the engine reconditioned to "as new"
So i think i will get a Q plate.
So the guys that have done a Z-CARS conversion can fit the kit and not need an SVA because they score enough points, but if in the future they decide to reshell using a fibre glass shell they would then need to do an SVA test...am i right.
ian.
Posted 14 September 2004 - 07:14 AM
They have been rung using an old V5
Siggy
Posted 14 September 2004 - 10:44 AM
Brakes, Hubs, drive shafts (although modified), steering rack, wheels. and you might get enough points to transfer the reg.
Posted 14 September 2004 - 01:04 PM
I think i will go the route of an SVA and Q plate.
At least i will be legal as i would not want the car impounded after i built it cus the dvla dont know what the hell it is if i got pulled over by the cops.
ian.
Posted 14 September 2004 - 06:36 PM
Posted 14 September 2004 - 08:30 PM
Posted 14 September 2004 - 08:59 PM
No problems because you are not using the shafts for driving the wheels. The modified drive shafts with Z-cars kit, is actually just the centre piece of the hub with the empty CV cups cut off. This just keeps the front hubs held together.Alburglar, how are the drive shafts modified for the z-cars kit as i read that cut'n'shut drive shafts wont pass an SVA test?
Can't find a pic right now so will go take another
Posted 14 September 2004 - 09:06 PM
Siggy
Posted 14 September 2004 - 09:22 PM
Posted 14 September 2004 - 09:27 PM
But to go the points way he will never do it, legally
Siggy
Posted 14 September 2004 - 09:36 PM
