rear brake shoes don't fit
9 replies to this topic
#1 Ste84
Ste84
  • 60 posts
Posted 04 January 2007 - 08:14 PM
Hi all,
The rear brakes needed replacing on my P reg Mini, so I went out bought some new shoes thinking this would be a quick easy job. However...
I got the new shoes on fine then went to put the drum back on and found that it didn't fit over the new shoes! I slackend the handbrake completly but still no joy. Then I phoned the place where I got the shoes from and double checked they were the right ones - which apparantly they are. I also inspected the inside of the drum for signs of any type of lip that might stop it going over, but the inside is fine.
Anyone got any ideas?
Edited by Ste84, 04 January 2007 - 08:17 PM.
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 04 January 2007 - 08:18 PM
did you turn the adjusting screw at the back ? :D
#3 Ste84
Ste84
  • 60 posts
Posted 04 January 2007 - 08:27 PM
Hi,
Yeah had the adjuster as slack as it could go. Do you know if there's specific types of shoes for different models because I was told that for the rear brakes there all the same?
#4 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 04 January 2007 - 08:30 PM
Have you fitted the shoes and the springs correctly? Try comparing them with the other side of the car (unless you've already changed them too?).
#5 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 04 January 2007 - 09:13 PM
Anyway I don't know if I'll get in trouble for doing this, but here's a useful link I found:-
Assembling Rear Brakes Link
#6 il-barba
il-barba
  • 839 posts
  • Local Club: malta mini
Posted 05 January 2007 - 08:36 AM
check the wedges on the adjuster. the slanting bit should be touching to the screw not the other side. as i had this problem yesterday, and after i managed to make the drum enter i noticed that the other side were the other way round!
#7 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 05 January 2007 - 09:58 PM
do they fit a certain way round? Im sure when i did mine i got one said upside down or back to front and it caused me some hassle. but was easily fixed.
#8 *DJH*
*DJH*
  • 4,972 posts
Posted 05 January 2007 - 10:02 PM
I Had This, Is It On Your Drivers Side (Nearside)
The Drum Will Have A Lip Inside Where The Drum Has Worn Over The Years.
It Will Need Turning On A Lathe.
Edited by DJH MINI MOTORSPORT, 05 January 2007 - 10:04 PM.
#9 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 05 January 2007 - 11:49 PM
Make sure the shoes arent just slightly off center, i.e. check for an even distance between the shoe and the lip on the backplate.
#10 Ste84
Ste84
  • 60 posts
Posted 06 January 2007 - 07:29 PM
Nice one, thanks!
I've been away from the pc and car for a few da6ys but I'll give it all a go see what happens.
