When i fitted the duplex chain and gears i countersunk the 2 bolts and used the countersunk screws. I also flattened the round raised piece on the timing cover that it tells you to do in the instructions with the gears. I was unsure wether to fit the tensioner or not so i called minispares and they said that it isn't needed on a duplex set so i didn't fit it.
Here's a link to a video i took that the noise can be heard on: http://smg.photobuck...=video-0010.flv
has anyone got any idea what's causing that noise? I have a sneaking suspicion that it's that timing cover that is catching but i did turn the engine over by hand on the pulley nut to check wether the chain and gears rubbed at all and i couldn't feel or hear any rubbing of any kind at all which then makes me doubt thats the cause.
Edited by adcyork, 06 January 2007 - 11:25 PM.
