carb is overflowing non-stop!
Posted 07 January 2007 - 12:28 AM
i need to sort something out very sharpish as i'm using as much fuel in the engine as i'm loosing onto the floor through the overflow!
anyone any ideas?
Posted 07 January 2007 - 12:42 AM
Posted 07 January 2007 - 12:45 AM
Edited by adcyork, 07 January 2007 - 12:46 AM.
Posted 07 January 2007 - 12:56 AM
if you remove the top of the float chamber and lift it out if it has a hole in it you will see fuel in the float.
if that isnt the problem then look at thr valve which is in the top of the housing.
let me know if you want to know more
Posted 07 January 2007 - 01:03 AM
Posted 07 January 2007 - 01:26 AM
then you will need a thin punch and rmove the float from the top. the valve will then pop out, if this is damaged then it wont do its job
minispares have a few differant parts, you can get the float chamber or just the needle valve
Edited by cowboy, 07 January 2007 - 01:27 AM.
Posted 07 January 2007 - 05:29 AM
The standard SU float valves have tips that wear out. There's also the chance that there's something preventing the valve from seating. Regardless, the parts aren't expensive and they're easy to replace.
Posted 07 January 2007 - 07:11 AM
Posted 07 January 2007 - 10:55 AM
Posted 07 January 2007 - 10:41 PM
Hey i had this problem as well and i just got a new seat and needle, also i put a fuel filter on it as it didn't have one in the first place..... i hurd that that if u don't run a fuel filter fine particles get trapt between the needle point which stops it from shuting off and thats sometimes it over flows out the top..... as i said get new seat and needle and if u got have a filter on the line get one...
i haven't got a fuel filter so i'm going to put an inline filter on as i think the reason it was overflowing was dirt blocking the jet like you said.
just a thought: are you sure you have the pipes connected up right?
yea i have the pipes on the right way deffo.
The problem has now sorted itself out and there is nothing coming out of the overflow at all so all is well. I'm going to replace the needle and float anyway just to be sure it won't happen again.
thanks for the help lads
Posted 09 January 2007 - 08:56 AM
Posted 31 January 2007 - 06:05 PM
Cheers BM
