Skuttle damages.
6 replies to this topic
#1 Big_Adam
Big_Adam
  • 7,435 posts
Posted 08 January 2007 - 05:40 PM
Yo
The previous owner of El Gordo (my brother) now has two functioning legs again and wants to get rid of his ... hmm .... how to put this ..... completly ;) saxo vts ..... yeah that's about right. Instead he wants to get another mini,
So he's been talking with a bloke who has one. Few things wrong with it in that it needs some new doors or the currents ones patching and sorting, new ignition barrel (stone me their expensive) and final (the biggest thing) "filler on the scuttle".
I know little of body but the scuttle is a rather important panel. Sorta hold the car together to a degree and he (my brother) says that it "needs a little filler"
At what point of scuttle rust is too far. I'm hoping the bloke my brother is getting this mini off is talking about a different panel. But if there holes in the scuttle should he just leave it and walk away from it?
Cheers for any info.
Peace.
#2 1984mini25
1984mini25
  • 8,787 posts
Posted 08 January 2007 - 05:48 PM
The scuttle tends to rot around the corner and under the bottom half of the windscreen seal and if it's anything like mini is/was the closing panels that help stop the spray from the road wheel rot first, allowing whats left to form a "shelf" for all the road muck to sit and rot the scuttle from the underside. So sticking some filler in there wont work and the rust will still be breading under there and come back through in a few months.
The only problem is to fix the scuttle properly you need to replace the wing/s and maybe even the front panel and then what ever else surely revels it's self while those panels are off.
And as for the ignition barrel, might be cheaper to source one from breakers.
Edited by 1984mini25, 08 January 2007 - 05:49 PM.
#3 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 08 January 2007 - 05:57 PM
cheap job to fix... in terms of repair panelm..... but you'll have to take the wing off too if it needs the corner replacing...
#4 minislapper
minislapper
  • 1,957 posts
Posted 08 January 2007 - 09:28 PM
You very often find that, if the scuttle is very badly rotted at the far edges, that the flitch panels beneath have also rotted. And the job keeps getting bigger........
#5 clubman katie B.F
clubman katie B.F
  • 1,524 posts
Posted 08 January 2007 - 11:50 PM
i know have just been there, just replaced 2 scuttle ends, two closing panels, two flitch panels, door steps, a posts...oh two new wings, a panels and front panel....this was what i thought was a quick bit of welding which got bigger and bigger, actually welding in the scuttle is easy, it's all the other bits that go with it
#6 shelby mustang
shelby mustang
  • 41 posts
Posted 13 January 2007 - 07:46 PM
minislapper is right, it realy justs gets morework i had rust in the right corner of the skuttle and flitch panels have also been eaten by rust it just becomes more work and very likly to find more when you take of the front wing
hope some help
#7 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 13 January 2007 - 08:21 PM
As I discovered a few years back:-
;D
