Fuel line problem
Posted 08 January 2007 - 10:17 PM
I've found no leaks even though the cars fuel consumption is excessive now and I've tuned the engine using a Colortune kit. Its running lean and has no oomph but it still gets through fuel faster than it was before.
My questions:
How can I cut the pipe (fuel line) to size with fuel in it? I'm going to get a proper sized braided fuel pipe with clips because I don't know if they have used a hose rated for fuel. I want to crop the fuel line back so it is lower in the engine bay but the tank is half full and I don't have a big enough container so I was wondering how I can cut the line back safely.
What can cause excessive fuel consumption in a Mini other than a leak as I have not found one and I believe that I have tuned the engine?
Thanks guys for any advise. I cannot return the car to the garage as it was a mates rate deal through a friend with no receipts. You live and learn.
Posted 09 January 2007 - 12:09 AM
Posted 09 January 2007 - 12:36 PM
firstly to stop the fuel coming out of the cut pipe, is to clamp it at the petrol tank end. you could always jacked the front up so the end your cutting is higher than the tank.
as for cutting the pipe itself, try using a small pipe cutter that some plumbers have, i believe they are fairly cheap to get in halfords.
the rubber hose they used should have fuel or petrol on it to denote what it can be used for.
as for the fuel consumption how bad is it?
i assume that you have check carefully for leaks etc.
anyway hope this helps you, and always remember to take extra care when dealing with petrol!!
Posted 09 January 2007 - 01:05 PM
There is a long solid fuel pipe which stretches the length of the vehicle, this terminates half way up the bulkhead with a right angled bend which should be approximately inline with the fuel pump on the back of the engine.... these are connected with a small length of flexible pipe... out of the other end of the fuel pump, there is another short flexible link to another solid (metal) fuel pipe which takes the fuel from the pump round the back of the exhaust to the carb, which again is connected to the carb with a short length of flexible pipe..
orginally there would be a clip which is connected into a square hole in the cross member ( bulkhead ) which holds the metal pipe away from the exhaust, but it's very common that this is missing..
Under no circumstances replace the metal pipe going around the exhaust with anything other than another metal pipe as this could end up in a small disaster and a burnt out mini...
So...
Which pipe is it you want to replace ?
Posted 10 January 2007 - 12:35 AM
The pipe that runs under the car comes in to the engine bay and is too long (and strangely enough already covered in verdigris after a month!). I need to cut about 7 inches off it. The rubber pipe that goes from the (copper) fuel line to the fuel pump is also too long. I've taken it off and there is no writing on it so I do not know if it is rated for fuel so probably safer to replace it (anyone know the exact size I need i.e apertrure in the middle and thickness of pipe?). I have jubilee and petrol line clips to put on.
The plan is to try and get a pipe cutter as recommended above this week. If I cant get one I'll continue using the car anyway so there is less fuel in the tank by the weekend. Then I'll clamp/drain the rubber pipe from the petrol tank at the back then remove it from the copper fuel line and empty any fuel in the copper pipe into a suitable container. Then I'll jack the front of the car up on an axel stand and blow through the front of the pipe in the engine bay to clear out any fuel. I'll then leave it overnight.
Next day I'll cut the pipe to size with a cutter if I have one otherwise I'll use a junior hacksaw (with a fire extinguisher nearby although should be ok as any fuel left should have evaporated overnight). Then I'll connect everything back up and hopefully all will be well.
As for the fuel consumption. The car has been fine for the last 700 miles but then I filled it up half-way home after 100 miles of my journey and it used half a tank to travel 60 miles. It usually gets twice that distance on half a tank. I can't see any leaks or notice any change in engine noise but the needle kept falling and usually you cannot notice it moving.
To clarify: I wont be touching the metal pipe on the other end of the fuel pump but I know that one that you mean GuessWorks.
Posted 10 January 2007 - 03:43 AM
I forget about clamping lines because when I assemble Mini tanks I install fuel taps right by the tank outlet!
Posted 10 January 2007 - 10:59 AM
I have a black flexi pipe going around the exhaust which was on when i bought the car so should i change this? If i do need to change this what pipe should i use?Under no circumstances replace the metal pipe going around the exhaust with anything other than another metal pipe as this could end up in a small disaster and a burnt out mini...
Posted 10 January 2007 - 11:09 AM
The fuel line for reference is 1/4" in diameter as std, or 5/16" on those fuel hungry motors.
Posted 13 January 2007 - 07:46 PM
I've written up what I did: http://www.detoxcomi...ini/mini15.html
I've included some photos.
Posted 13 January 2007 - 07:53 PM
Posted 13 January 2007 - 08:37 PM
Posted 13 January 2007 - 09:19 PM
Copper fuel line??
It looks like copper. I asked for a fuel line about 6 months ago at a motor factors and they sold me 12ft of this stuff that looks like copper. It has verdigris on it so I assume its copper. You've got me a little concerned. Should I change the fuel line? What do you use? The guy at motor factors say everyone uses they stuff he sold because its more bendable.
Posted 13 January 2007 - 09:42 PM
Copper fuel line??
I found this online: "Fuel lines, which connect all the units of the fuel system, are usually made of rolled steel or, sometimes, of drawn copper. Steel tubing, when used for fuel lines, is generally rust proofed by being copper or zinc plated. Fuel lines are placed as far away from exhaust pipes, mufflers, and manifolds as possible, so that excessive heat will not cause vapor lock. They are attached to the frame, the engine, and other units in such a way that the effect of vibration is minimal, and so that they are free of contact with sharp edges which might cause wear. In areas where there is a lot of movement, as between the car`s frame and rubber-mounted engine, short lengths of gasoline resistant flexible tubing are used."
It looks likes some lines have treated copper in them I guess to make them more plyable as steal is pretty hard to bend. I have copper brake lines and they are a completely different colour and easier to bend. My fuel line is a light brown steel colour and only just bendable. Other web sites talk about copper fuel lines so I guess it is not uncommon.
Posted 14 January 2007 - 12:01 AM
However, if it is a pure grade copper, this is all i was conserned about - The fuel passing through the copper line disolves a tiny amount of copper. This then plates out over a prolonged period ( note the operative word being prolonged) at the coldest point, which happens to be the jet and needle in the carb, thus affecting the performance of the carb.
I'll be very honest and say that if it is a pure grade copper, then leave it and dont wory about it, its gonna take years for any sort of effects to happen. It is far more prominant in ijnjection engines as the injector orifaces are very small to start.
This should be considered though when buying in the first place, now that you know.
Like i said, its not worth worrying about, certainly not worth ripping it out and replacing it, after all it may well be Kunifer, which is a Nickle Copper alloy, though i am sure it shouldnt corrode as it is. The salty roads help corrossion, so what your seeing isnt realy a surprise to me.
http://en.wikipedia....tal_deactivator
As you were soldier
Edited by Mini Sprocket, 14 January 2007 - 12:07 AM.
