Carpet Adhesive
Pob
, Sep 15 2004 01:48 PM
6 replies to this topic
Posted 15 September 2004 - 01:48 PM
I've got some new carpet for my mini, what kind of adhesive would you use to stick it down?
Many Thanks,
Dan
Many Thanks,
Dan
Posted 15 September 2004 - 01:53 PM
i have some stuff called stickaflex or something along the lines.
Big tin, £2.39...from my local DIY shop. I would spray around the edges and a small bit in centre so if u ever need to get the carpet out it aint gunna be too messy.
Posted 15 September 2004 - 03:00 PM
I use roofing felt adhesive, it comes in a 2.5l tin. Don't use it if you plan on removing the carpets soon thou as its a b*strd to get off!
Posted 15 September 2004 - 03:08 PM
Thanks for the info!
Dan
Dan
Posted 15 September 2004 - 07:46 PM
i only stuck the front wing sections of my carpet with glue, teh rest of the carpet is just in there loose, with no problems at all
:wales:
:wales:
Posted 15 September 2004 - 08:56 PM
same here + them bits just under the doorsi only stuck the front wing sections of my carpet with glue, teh rest of the carpet is just in there loose, with no problems at all
:wales:
rob
Posted 16 September 2004 - 07:49 AM
Yep best way to do it, stick the inner arch bits and the bits under the door then push the rubber stripping over them. Everything else should lay nice and tight once it is cut properly. I use Ultra High Temp Impact Adhesive, but again dont use it if you want to unstick it later.
