is it ok to just prime the bare metal with rattle cans?
9 replies to this topic
#1 adcyork
adcyork
  • 490 posts
Posted 16 January 2007 - 12:22 AM
i've just fitted some new windscreen corner panels onto my mini and as it sits outside and as there is bare metal exposed until it is resprayed there is a slight bit of rust formed on the bare surfaces. My question is basically, can i just clean up the metal to shiny steel again then just put some halfords rattle can grey primer on the metal to stop it rusting. Then rub it down and paint over it when the car gets resprayed? Or will all the halfords primer need removing before the respray? I just don't want to waste my money on rattle cans if it's not needed.
thanks
Andrew Cook
#2 neil_g
neil_g
  • 880 posts
Posted 16 January 2007 - 10:21 AM
id like to know this too, at some point soon i need to start sorting my shell..
#3 pinch
pinch
    Das Pingu's
  • 527 posts
Posted 16 January 2007 - 10:55 AM
you can buy UPOL grey etch primer from halfords which i guess should be of better quality then the regular primer, and is compatible with paints that go on top....
Edited by pinch, 16 January 2007 - 10:55 AM.
#4 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 16 January 2007 - 10:59 AM
Yup Upol is good i've used that. Standard stuff from Halfords is Acrylic, and i've had no probs with that either But Upol seemed to have a better finsh straight outta the can.
Yes you can prime it and then rub it back down... but i would't drive the car with bare primer patches it will just rust.
#5 neil_g
neil_g
  • 880 posts
Posted 16 January 2007 - 11:23 AM
mines off the road anyway in a garage (with no more leaks hurrah lol)
#6 midridge2
midridge2
  • 1,794 posts
Posted 16 January 2007 - 02:02 PM
dont use primer as its hydroscopic and will absorb water, use etch primer.
#7 kirk
kirk
  • 143 posts
Posted 16 January 2007 - 08:01 PM
as mid said primer is pourus so water will get behind it and rust it still
makes me laugh when u see chavs driving round with cars painted in primer pissing it down with rain
#8 philc
philc
  • 839 posts
Posted 19 January 2007 - 04:16 PM
in line this, is it right that you primer onto bare metal or do you treat it first or use some other product and then primer.
excuse my ignorance!!!!
#9 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 19 January 2007 - 04:57 PM
You could etch prime it. :-
I think etch primer is zinc rich... so great for rust prevention on panels.
#10 blacktulip
blacktulip
  • 6,224 posts
Posted 19 January 2007 - 11:17 PM
the area to be primed has to be very clean. use thinners with a clean rag to remove grease dirt etc, otherwise the primer wont stick properly :-
