MOT advisory
17 replies to this topic
#1 JoeBodge
JoeBodge
  • 716 posts
Posted 19 January 2007 - 03:40 PM
Went to tax my mini the other day. and noticed i had an advisory for my next MOT.
It says:
"003 Inner Front track rod end ball joint has slight play [2.2.B 1f]"
What does this mean?
what bits do i need to replace it?
Do i just need one of these?
JoeB
Edited by JoeBodge, 19 January 2007 - 03:50 PM.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 19 January 2007 - 04:16 PM
Yes, this is the product of the computerised MOT system, when it last had it's MOT the examiner noticed that it was suspect, but not bad enough to fail the vehicle on... At your next MOT, they should take note of the advisories, and will take particular consideration as to it's present condition. So is advisable to change ( may save you a retest fee which will be at least 3 times the cost of the trackrod end ! )
Also check out our sponsors... http://www.minispare....aspx?pid=32671 add your 5% discount to that :-
#3 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 19 January 2007 - 05:07 PM
avoid the ones that look like this....
i found the rubber tends to split after a few months !!!!! :-
#4 JoeBodge
JoeBodge
  • 716 posts
Posted 20 January 2007 - 12:03 AM
i will get one from partco at sum point - and change it ovver when i change from drums to disks.
dont suppose you know which side its goin on about? passenger or drivers? or is it best just to hav a ganders under the car?
i just remeber the guy talking about having to change my steering rack because of this, and i was like eh? - thats y i got all confused - im not really this dumb usually :- lol
Edited by JoeBodge, 20 January 2007 - 12:04 AM.
#5 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 20 January 2007 - 08:02 AM
It states inner not outer track rod end. Play on the rack
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 January 2007 - 08:33 AM
Nice spot Koss, when mine had a similar issue, they wrote it down as steering rack and not track rod, hence my statement.. but if it is the ball joint in the rack, then it's a new/recon rack
Tried it on the next year, and it failed :-
Edited by GuessWorks, 20 January 2007 - 08:34 AM.
#7 koss
koss
  • 1,399 posts
Posted 20 January 2007 - 08:53 AM
The problem with the new mot system is,
on the fail page the reasons are allready typed out in the text box and you just choose one, the explanations are carp.
The log on and log off every 45mins is carp aswell. used to get 10 tests per day now only 8. And 45mins retest :-
#8 camp freddy
camp freddy
  • 3,696 posts
Posted 20 January 2007 - 10:08 AM
inner track rod end would mean the near side one ( left), it may pay you to change both track rod
ends if you are also changing to discs, seems sensible
#9 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 20 January 2007 - 10:16 AM
(checks mot) anyone have a spare steering rack???? :-
#10 koss
koss
  • 1,399 posts
Posted 20 January 2007 - 10:23 AM
It should clearly state N/S/F or O/S/F
The way i read it, a bit like inner or outer cv joint
Edited by koss, 20 January 2007 - 10:25 AM.
#11 minislapper
minislapper
  • 1,957 posts
Posted 20 January 2007 - 01:01 PM
If they found play somewhere, just jack up the car one side at a time and check where it is.
#12 JoeBodge
JoeBodge
  • 716 posts
Posted 20 January 2007 - 07:12 PM
now im even more confused :S but will get it up on ramps at sum point and have a wiggle - will change the track rod end anywayz - thanks :-
#13 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 20 January 2007 - 07:25 PM
We have alot of bother at work with the mot failure sheets.
It 'automatically' inserts that its a free re-test if the vehicle is left at the test station for repair. Or half fee if the vehicle comes back within 10 working days.
Problem is, we are a goverment authority and only do the tests, not repairs. So the customers say this is unfair, as anywhere else would have fixed it and retested for free.
Its worse if it only fails on a couple of blown bulbs, as it now costs them £25 re-test fee and a couple of 30p bulbs :S
#14 camp freddy
camp freddy
  • 3,696 posts
Posted 20 January 2007 - 10:39 PM
It says:
N/s track rod end , not cv joint !
#15 camp freddy
camp freddy
  • 3,696 posts
Posted 20 January 2007 - 10:43 PM
The garage where i take my vehicles always lets me take the vehicle away to repair faults and doesn't
charge a re-test fee ! They can charge if they want to if the vehicle is taken away.
