oil pressure plunger stuck.
3 replies to this topic
#1 daniel_johno
daniel_johno
  • 310 posts
  • Local Club: AMOC
Posted 22 January 2007 - 05:24 PM
ive finished my quick rebuild of my 1275 engine but when building it noticed the oil pressure relieve valve plunger wont come out. i plan on fitting a ball bearing in its place but need to get it out.
Is there an easy way of removing it?
Daniel
#2 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 22 January 2007 - 05:43 PM
Hi, what you can try doing is put a flat bladed screwdriver in the lunger and press it against the wall while trying to slide it out. Failing that, if you have a threadmaking tap of suitable size, push that in there so it just grips the plunger, then try extracting it that way. But be careful not to mark anything else. Doing this means that you may need a new plunger to use when you assemble everything back up.
Lastly, if still no luck, turn the engine over very briefly, and the build up of pressure should eject the plunger, but there will be a mess of oil you will have to clean up afterwards!!
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 January 2007 - 05:57 PM
The only 100% successful way of removing a stuck oil pressure valve is a spark plug tap (14mm) fits perfectly...
#4 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 22 January 2007 - 08:15 PM
i used an M6 rawl bolt and a pair of plyers!! locked the rawl bolt into the plunger then pulled it out with the pliers!
