thanks
BIKE VFR POWERED MINI
Shell
This is B reg mini that has been fully rebuilt using genuine heritage panels and then given a excellent paint job in 2pack ford radiant red and old English white roof.
Engine
The engine is a Honda VFR 800 VTEC which is a V4 it has only covered 4000 miles. Starts first time and runs perfectly.
The engine comes out to a free flow straight thought manifold ad ending in a blue anodised Micron Can
Front
The front of the car has been fully rebuilt to a exemplary standard with new Genuine wings and front panel. The front subframe is also brand new, in a powder-coated Blue onto this you can see a Bespoke fuel cell that sits behind a huge Cosworth radiator. This is piped to the engine with Blue silicone hoses – water level is monitored by a Bespoke Alloy Header tank in the back of the car. A Cosworth fuel pump and filter can be seen this gives more then enough fuel pressure which is needed in the injection engine! The front arms are fully adjustable for camber caster and Toe in and out! Allowing for optimum handling settings
Brakes
The front brakes are brand new 4 POT callipers with Goodrich Braded hoses all round to a brand new master cylinder. Vented Discs. Rear Brakes are metro Sliding type again with Goodrich braded all round. The brakes are biased 47% Rear and 53%
Rear
the engine sits in the middle of the car. The drive comes from the engine to an adjustable chain driven BMW diff – going down the modified drive shafts to the metro hubs which are fully adjustable for camber caster and Toe in and out! Allowing for optimum handling settings.
The car sits low due to the adjustable coil over shockers (Protech front AVO rear) and has 4 brand-new 13 x 7” super lights with Bridgestone tires on.
This is virtually finished it can be driven there are very minimal things that are needed to finish this road going super-toy!!! Just wiring up of lights, glass – put the bonnet and boot on MOT etc
NO REVERSE FITTED YET
THANKS GUYS
