Any powder coaters here?
Posted 24 January 2007 - 12:35 AM
I'm in need of getting my wheels powder coating... I'm sure hammrite isn't up to the job.... or is it?
I have 4 10x6 KN Murcary's, I'd like Matt/Satin Black if possable...
Anyone here able to do this for me... willing and paying Will cover all costs, postage etc....
Mart
Posted 24 January 2007 - 01:43 AM
<|ben|>
Posted 25 January 2007 - 12:34 AM
dont suppose wheels can be powder coated in white can they? also can the powder coat be done over a little body filler?Where are you based. Theres a powder coating firm just down the road from my house. They are fair priced. I can pop in one day and get you a quote if you want?
<|ben|>
Posted 25 January 2007 - 03:59 PM
Posted 25 January 2007 - 04:27 PM
<|Ben|>
Posted 25 January 2007 - 04:39 PM
Posted 25 March 2007 - 07:32 PM
Id say powder coating is the best way to go. I painted mine (remember u have to use special alloy primer if you go to bare metal) using hammerite for the backs and rattle cans for the fronts. Gave them a generous coat of colour and then lacquer, they looked awesome but the brake dust on the fronts just wrecked the paint and took off the shine!! I painted mine white so wasn’t a major problem, but expect to see the paint chip slightly and loose its shine after a few months.
Powder coating for mine was quoted at 40 quid a wheel!!!!!!!!!
Good luck
Posted 25 March 2007 - 07:39 PM
<|ben|>
If this is the same one i am thinking of I got a MR2 rear subframe and a few other bits like ARB's all done for £50 and i had the same day turn around.
VERY good!
Posted 26 March 2007 - 08:47 AM
Posted 28 March 2007 - 09:37 AM
Powder coating can be used over lead, so you could repair minor damage using lead loading.
Gotta be careful on wheels though, if you use a fair bit it might throw the balance right off.
Posted 28 March 2007 - 11:13 AM
my wheels were done in a place in my town and it was bout £40 a wheel, this was for sand or shot blasting (i can't remember which) then bead blasting then powder coated. However on steel wheels they do not need to be bead blasted. so will cost slighty less. I highley recommend it because it does not chip as easily as if you spray canned them and is and excellent finish.
Posted 28 March 2007 - 12:49 PM
Posted 28 March 2007 - 01:58 PM
Personally I don't think powder coat is that great, especially on steel wheels. It can chip quite easily, and as soon as water or rust gets underneath it, it will peel off in long strips!
My brother had is 106 rallye wheels (steel by the way) powder coated and it has been fine it has been about a year sine they were done. They would be slightly better if he was to wash them more often so the brake dust did not attack the paint . We did try spraying them but that did chip off far far far to easily and was not such a good finish.
Posted 28 March 2007 - 02:15 PM
Posted 28 March 2007 - 03:43 PM
