air horn
14 replies to this topic
#1 minimayfair633
minimayfair633
  • 173 posts
  • Local Club: The Rebels Mini Club
Posted 24 January 2007 - 10:56 AM
I have a twin air horn to go on my mini with compressor, where would be the best place to put this and where
would be the best place to wire it with a swith into the dashboard?
#2 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 24 January 2007 - 11:38 AM
I would wire it through a relay (this is a must) and have a switch on the right hand side of the car along with the fog light switch.
However, not wanting to scare you,.... but i though 'Twin' air horns were strictly illegal :D but i'm no 100% on that...
Edited by Retro_10s, 24 January 2007 - 11:38 AM.
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 24 January 2007 - 12:29 PM
Single tone are LEGAL. musical ones AS A MAIN HORN are illegal.
#4 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 24 January 2007 - 12:47 PM
As i thought, Twins are a 'no no' and it can't be a main moosical one.
#5 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 24 January 2007 - 12:50 PM
If both horns fire at the same time, then they are legal. - Two notes produce a single tone.
I have mine mounted to the inner wing at the front of the car on the left as you look at it, with the compressor attached to a bolt was holding something else on, mine is wired throguh a relay, which is essential, and I've wired it to a 3 way switch (was the only one I had) so I can have the air horn on, no horn on, or the original horn on.
BAAAAAAAAAAAAAAAAAAAAAAAAAAAAAARP!
Edited by paulrockliffe, 24 January 2007 - 12:51 PM.
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 24 January 2007 - 12:54 PM
fitting the horns behind the number plate is a good place and still leaves the engine bay clear :)
i have my air horns on a change over switch so i can use the standard horn of the air horn from the ind actor stalk switch :D
#7 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 24 January 2007 - 01:19 PM
if they are a twin horn system that fires both at the same time then it is perfectly legal to have them as your main horn. If they play a tune then you have to have them switched as you must retain your original horn.
Seen them fitted behing the numberplate and it's a great idea as it doesn't clutter the engine bay!
#8 Big_Adam
Big_Adam
  • 7,435 posts
Posted 24 January 2007 - 01:31 PM
aye, I have twin horns but they give off a single tone. I asked Mr MOT about it when I had the MOT last year. He said "yeah it's fine".
#9 Xiao_Bin
Xiao_Bin
  • 621 posts
Posted 24 January 2007 - 02:28 PM
mr MOT makes sure your care is safe for you and others, it can pass a MOT and still be illegal :D
#10 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 24 January 2007 - 02:53 PM
We have twin air horns fitted and the mini has passed the MOT with them on. Now in the testers manual it states the criteria for a horn, and in the text it mentions that a horn should not be 'stridant', which I take as to mean not to frighten (pedestrians etc).
Now if air horns are not 'stridant' I dont know what is. Obviously apart from the spectacular sounding horns on hornblasters.com.
David
#11 Big_Adam
Big_Adam
  • 7,435 posts
Posted 24 January 2007 - 03:07 PM
bah, airghorns are very useful tho. Especially for making stupid people who are doing their hair while the lights are green and still not moving to take noticed. Man she jumped so much.
ah memory's.
#12 minimayfair633
minimayfair633
  • 173 posts
Posted 24 January 2007 - 04:37 PM
My air horn has two cones but only produces a single tone.
#13 minipip
minipip
  • 1,591 posts
  • Local Club: TMF SE
Posted 24 January 2007 - 04:55 PM
they are especcialy usefull at shows when people arnt up yet ither as twice found out when he sleped in, drive upto tent, BRRRRAAAAAAAAPPPPPPPP, he pokes his head out the tent with some words i shall not repete on here LOL
B)
#14 minipip
minipip
  • 1,591 posts
Posted 24 January 2007 - 04:59 PM
B)
#15 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 24 January 2007 - 06:04 PM
is that 2 people you woke up or the same person twice ? :D
