avonbar phase 1 cam
3 replies to this topic
#1 blacktulip
blacktulip
  • 6,224 posts
Posted 27 January 2007 - 11:02 PM
im in two minds whether to fit a phase 1 cam i bought from avonbar. the engine is a pretty standard turbo unit (rebuilt) apart from lightened clutch kit and an intercooler, 8psi actuator (to start with). will it be worth it or shall i just leave the standard cam in. i aim to get 10psi when im finished.
#2 steveobennet
steveobennet
  • 944 posts
  • Local Club: stu's turbo club
Posted 28 January 2007 - 06:48 PM
not that i'm going to be of any help but i was wondering whether you could fit some 1.5 rockers instead of a cam? would the output be the same, or would the rockers give more torque and the cam more hp?
#3 Sam
Sam
    Wish i was in T.O.W.I.E
  • 2,323 posts
Posted 28 January 2007 - 11:58 PM
Standard cam is lame, if you've got it, you might aswell fit it ;)
#4 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 31 January 2007 - 06:32 PM
A decent cam will make the world of difference, i'd fit it, as long as it's in good nic.
As for fitting 1.5 rockers on a standard cam, yes this will make a difference. You'll be getting more lift at any given point, but the duration and in/ex opening times will obviously remain the same.
