timeing chain cover, gasket question
4 replies to this topic
#1 marksmini
marksmini
  • 49,441 posts
  • Name: Mark
Posted 30 January 2007 - 02:41 PM
on the timing chain cover if ive removed it and the old gasket was C**p, would a silicone gasket be ok to refit with?
any idea?
Mark
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 30 January 2007 - 02:46 PM
I'd suggest getting a proper gasket.
Insto gasket isn't the greatest stuff in the world to be mixing with oil. My timing chain was fairly coved with that stuff as the previous owner has used 3 gaskets and insto stuff too.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 January 2007 - 02:47 PM
With the timing cover, because they are very prone to getting bent out of shape and then leaking like a sieve... I use a gasket which is then smeared with a silicon sealant on both sides...but not too much just a thin bead will do...
#4 marksmini
marksmini
  • 49,441 posts
  • Name: Mark
Posted 30 January 2007 - 03:11 PM
brill thank you everyone, think i will use both then, Ta
Mark
#5 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 31 January 2007 - 11:11 PM
any idea?
Mark
call yourself a teacher lol
if you cant get a gasket, use gasket paper and loctite 574 instant gasket, at the worst use hylamar
nice to see you mark now get that car n the road
