flitch panels
3 replies to this topic
#1 Jay81
Jay81
  • 99 posts
Posted 30 January 2007 - 09:47 PM
Hi just a quick question can the inner flitch panels be repaired with fibreglass so it will pass an mot
i know it is not beating the rudt but i do need a quick repair and no welding experiance and cannot get the mini to a welder
cheers Jason
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 January 2007 - 09:52 PM
depends where... if its up by the airvent the you'll probably get away with it..
Anywhere with a foot of a subframe mount, sill or suspension mount then nope, should be welded...
#3 1984mini25
1984mini25
  • 8,785 posts
Posted 30 January 2007 - 09:55 PM
You could, BUT just because you've coved over the problem doesn’t always mean it will go away, instead it will get worse and you'll end up having to do further repairs.
I know as I found out the whole of my drives side flinch panel was just filler.
Edited by 1984mini25, 30 January 2007 - 09:57 PM.
#4 Jay81
Jay81
  • 99 posts
Posted 31 January 2007 - 05:43 PM
ok cheers how hard are they to replace
