Engine Rebuild
Posted 30 January 2007 - 11:58 PM
I have decided to rebuild my 1275 spi as the one of the planet wheels broke up in the diff and ended up in a million pieces in the bottom of the gearbox.
(sorry if i use the wrong name for things)
This is my first complete engine rebuild (i thought it would be the best way to learn) and need some help with checking the condtion of some parts.
I've striped the engine down checking a taking pictures of most things i'm not sure about???
The head and gearbox i'm ok with its the block componets i'm not sure on. i.e. crank, cam, pistons, bearings etc.
1. This is the condition of the crank and bearings, there is some wear on both the bearings and crank the 4th con rod bearing is the worst with pitting and the centre crank bearing hole has also worn badly. (see pictures) Is this crank salvagable or would it be best to get a replacement with new bearings. If so where is the best place to get one from.
2. The piston cambers seem ok apart from camber 2 as the head gasket was blown and there was water in that camber. There is also very very slight vertical scoring but i'm not sure what is normal??? (see pictures). Is it just the case of have them honed out??
3. The centre and flywheel end bearing for the cam shaft are quite worn. I'm not sure how to replace these??? (see pictures)
I'
thanks for any help.
Posted 31 January 2007 - 12:03 AM
and may benifit from a hone down the bores, with new rings...
Posted 31 January 2007 - 12:09 AM
Posted 31 January 2007 - 12:12 AM
Posted 31 January 2007 - 12:29 AM
it was the condition of the crank that was worrying me the most especially the centre hole that has gone. and Weither it needed re grinding. I've attach a few more pictures.
Where would be the best place to get rings and bearings from and which type would i need??
Posted 31 January 2007 - 12:43 AM
Posted 31 January 2007 - 01:01 AM
dont forget to fit a new oil pump and since u have it all apart a magnetic oil pickup in the back of the gearbox(behind the pickup pipe) to make sure u dont get any steel floating round ur engine again, i kno the filter shud take it out but the filter housing does have a oil bypass!!!!
Posted 31 January 2007 - 01:05 AM
Posted 31 January 2007 - 01:25 AM
Fresh regrind crank, complete with a full set of new bearings. Crank balanced and ready to fit, £85 all in excluding exchange unit.
http://www.minisport...or-product.html
At that price why worry whether the original is good or not, you'd pay near that for a full set of bearings anyway. I walked into the shop yesterday with a crank in need of a regrind, half an hour later walked out with a Nitrocarburised 10/10 regrind crank and a full set of bearings for £145. Now that is service. The machine shop I use couldn't even touch it for that price.
Posted 31 January 2007 - 01:29 AM
depends if u want to spend £70 odd plus suitably oversized bearings or jsut a new set of std bearings with ur current crank!
Thats £72.50 plus VAT and includes bearings, all of them!!
Edited by Mini Sprocket, 31 January 2007 - 01:32 AM.
Posted 31 January 2007 - 01:41 AM
Fit only the magnet that has a gauze, the one without has potential to kill the oil pump in one foul sweep!!
http://www.minispare....aspx?pid=35169
Posted 31 January 2007 - 01:43 AM
Posted 31 January 2007 - 01:45 AM
Now do you know why the others are BAD!! ?.....................
Posted 31 January 2007 - 09:29 AM
And one without a trap
Whats the thought on putting a strong magnet into the oil filter ?
