Stem Seals
Posted 08 February 2007 - 06:04 PM
I asked the guy in the shop and he said that the exhaust valves have O-rings instead of stem seals. But there are no O-rings in the kit??????
Posted 08 February 2007 - 06:12 PM
The argument is made that they prevent the vacuum in the intake manifold from sucking oil down the stem and burning it. The exhaust valves also appear to benefit from the little bit of oil that runs down their stems.
Posted 08 February 2007 - 07:20 PM
Posted 08 February 2007 - 08:25 PM
Posted 08 February 2007 - 08:30 PM
BMC/BL/Rover (like other companies) did things the most cost effective way... but they didn't leave the 4 seals off the exhaust by accident or to save about $1. If it meant risking a warranty engine rebuild/replacement the exhaust seals would be there from the factory.
Posted 09 February 2007 - 09:03 AM
Posted 09 February 2007 - 04:31 PM
rubber seals on the exhausts valves would degrade very rapidly, this would probably cause the valves to get sticky and slow to return which will in turn cause loss of compression and eventually failure to fire.
Guess what the previous owner had done to the cylinder head on my car!!!!!
Posted 09 February 2007 - 05:02 PM
Posted 09 February 2007 - 06:36 PM
Posted 09 February 2007 - 07:52 PM
Anyone got one ?
Posted 11 February 2007 - 11:45 AM
Yeah, I know all that but this has got me thinking...given the speed in which things are happening in the head and the heat being spread all around etc what would the difference be? I mean, you wouldn't be able to touch one would you? So, in relation to the question of why will the stem seals melt on the exhaust and not the inlet, why aren't they made to withstand the extra heat on the exhaust?The difference in valve stem temperatures is significant. The inlet valves are cooled by the incoming, unburned charge. The exhaust valves open while the charge is ending its burn so they are exposed to very hot gasses. The valve head transfers this heat up the stem.
Posted 12 February 2007 - 02:33 PM
Keep in mind the purpose of the seals is to keep oil from being drawn off the head. Intake valves seals prevent manifold (port) vacuum from drawing oil down along the relatively cool exhaust valves, into the chambers, and burning. By contrast, the exhaust valve are in an environment where the ports are pressurized (generally). You aren't likely to draw oil down along them and if you did, it would be oil blown out partially burnt in the exhaust. As I mentioned earlier, the exhaust valves have a more demanding environment and need a little bit of lube anyway. So, particularly when the guides are new and relatively tight, you don't necessarily want the seals. They are preventing a limited amount of beneficial oil from oozing down the guides.
If you insist on going with exhaust valve stem seals, there are certain seals for other cars that are made of Viton instead of the nitrile rubber used on most intake seals. The Viton seals can handle the higher temperatures. Sorry, I can't tell you which cars use these seals. There's a guy in the U.S. (Todd Miller, who is a guru in the MG-1100/Austin America world) who has found these Viton seals and was selling them to anyone who was interested in them. Google "Todd Miller" and "ADO16" and you'll find his web site. He can either sell them to you or probably direct you to an alternate source.
Posted 12 February 2007 - 03:09 PM
WOW!! Is this place a mine of information or what, you kids don't know you're born, when I had my first car Haynes was all you got, if you were lucky!!
Keep up the good work!!
Edited by Bass Man, 12 February 2007 - 03:10 PM.
Posted 13 February 2007 - 02:13 PM
Please see this related thread which surfaced just yesterday:
http://www.theminifo...x...f=6&t=41442
