m3ntalist did this for me in photoshop:
What do you think?
Current Bonnet:
Done in photoshop:
I really like the look of my car without its bonnet badge, but tom told me on irc that if I do take it off instead of just painting the filler that fills the holes left by the badge I'd have to have the whole bonnet repsprayed
How much would it cost to respray my bonnet?
I also think I'm going to do this with my boot...
So how much would it cost to repsrpay my boot?
Many thanks
Removing my bonnet badge?
BlAck0ut
, Sep 30 2004 07:20 AM
8 replies to this topic
Posted 30 September 2004 - 07:20 AM
Posted 30 September 2004 - 11:09 AM
I used fireworks though
Posted 30 September 2004 - 11:30 AM
just spary a bit yasefl mate!
its not hard.........primer, colour and laquar with mine!
then loas ov t-cut and polish!
Posted 30 September 2004 - 11:35 AM
I had a brand new bonnet with the black coating on it and had it sprayed in two pack black with two white bonnet stripes and it cost £60 at a body repair centre.But phone around for quotes as i did ,i had some as high as £170 for it so look around so good luck.
Posted 30 September 2004 - 02:45 PM
hmmm, thing is I dont have any of the above
What would I need? Filler, Primer, T cut, Polish....?
How hard is it to do?
Steps?
Many Thanks
Steps?
Many Thanks
Posted 30 September 2004 - 03:10 PM
when you fill the holes in get someone to weld them up first because after a while the filler will crack and then it looks a mess. Just weld the holes up, grind them flat and then skim with filler. As for spraying, if you know the paint code then go along to an autopaint shop and get them to mix an aerosol up, it will cost you about a tenner but you will get a brilliant finish and very good match with it.
Posted 30 September 2004 - 03:56 PM
OK, thnx Philster
...but is there anyway of finding out my paint code no.?
lol this keeps going on...
Posted 30 September 2004 - 07:53 PM
The paint code should be on the little plate in the front left of your engine bay, along with your VIN number.
Posted 30 September 2004 - 08:47 PM
its not that hard spraying to be honest! i though it was something that only a special few people could do to ge ta good finish any way, i prooved my self rong though i find if you heat the paint up so its sorta warm it goes on better! then when its all done T-cut the surrounding area and blend it in! nothing to it realy
