spot weld? / seam weld?
11 replies to this topic
#1 Ste84
Ste84
  • 60 posts
Posted 09 February 2007 - 06:58 PM
Hi all,
My mini faild on it's MOT for the sills rotton (as well as many other things). I've done all the other stuff that needed doing and left the welding to a welder. Two brand new sills and all the holes and wheel arches patched later I thought it's be fine getting through the re-test. Oh no how wrong could I be -
The MOT place said - "Sills had to be seam welded all the way along not spot welded - fail"
Welder man said - "The MOT bloke doesn't know what he's talking about, a brand new panel can be spot welded on as long as it's a complete panel and not just a patch. It's also better to spot weld it than to seam weld it." He also added "Here's a list of MOT companies who I weld for, any of these will agree with me and pass it"
So I said I'd check it out with someother MOT companies first.
Anyone know who's right and who's wrong?
Cheers Ste,
ps - Welder man did say that I could bring it back and he'd take them off and seam weld them for nowt if I wanted.
#2 chairchild
chairchild
  • 606 posts
Posted 09 February 2007 - 07:08 PM
The welder is correct - and your MOT man is an arse.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 February 2007 - 07:43 PM
Depends what sill he used... If it's a geninue sill ( ie as fitted in the factory ) then it can be spot welded, if it's an oversill or wide sill then YES it needs to be seem welded as it is a non original fitment panel...
#4 vasi
vasi
  • 897 posts
  • Local Club: Minis 'n' Oatcakes
Posted 09 February 2007 - 10:08 PM
My rule of thumb is, if in doubt, seam weld throughout.
Irrespective of factory spec, genuine panels and strength issues. I would personally not consider spot welding any groundside panel as gaps in paneling are tinworms favourite meal.
#5 camp freddy
camp freddy
  • 3,696 posts
Posted 09 February 2007 - 11:42 PM
as guess works said
#6 pinch
pinch
    Das Pingu's
  • 527 posts
Posted 10 February 2007 - 09:55 AM
guessworks is 100% right......
#7 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 10 February 2007 - 12:43 PM
im with GW! 100% correct!
#8 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 10 February 2007 - 08:17 PM
Where there is a factory join you can use the same method to fit a panel at that point/seam
where there was no factory join you have to seam weld
so , the sill can be spot welded along the doorstep/rear 1/4 and spot welded along the bottom edge as well as long as it is the factory type narrow sill
where a larger type sill is used the lower seam must be seam welded
so as GW said
BUT i would love to know who it was that started the blatent lie about it is illigal to weld a subframe .
'because if that was the case all new subframes from the factory would be illigal !
#9 minimanclive
minimanclive
  • 1,108 posts
  • Local Club: LSMOC
Posted 10 February 2007 - 08:32 PM
I've heard that the MOT tester wouldn't be too happy if a rotten rear subframe had been repaired with the plates you can get to weld on the bottom.
#10 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 12 February 2007 - 01:43 PM
spot welding is some applications is stronger than seam welding, the mot rules i dont agree with in full but it a rule book they work too because the front part of the sill can be missing for a mot, alone with the botom part of the rear qtr panel where it meets the sills can be rotten and that aint a failure either.
other non failable item is play within steering rack,
dave
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 February 2007 - 03:07 PM
You've lost me there Dave.... ( not on the welding, but on the fail points )
#12 Ste84
Ste84
  • 60 posts
Posted 12 February 2007 - 08:07 PM
Hi,
Thanks for everyones reply. I've spoke to a few different MOT places and got different answers - some are saying "no has to be seam..." others are saying "fine if it's a complete panel". So I'v got it booked in to one of the ones the welder recomended to me - at least this way I know it'll pass.
I'd be interested to know what the official VOSA legislation is though as i've had so many varying views.
Ste
