Gearbox question for Guessworks
10 replies to this topic
#1 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 09 February 2007 - 09:05 PM
Hello
I was wondering how you remove the main double roller bearing from the casing, do you use a special tool or one you have made yourself?
Thanks for the help
David
#2 james the clubman man
  • 563 posts
Posted 09 February 2007 - 09:17 PM
why dont you send quessworks a pm???
#3 icklemini
icklemini
  • 2,982 posts
Posted 09 February 2007 - 10:52 PM
I use the special 'horse shoe' tool...
can make them yourself either from the end of a old large open ended spanner... or a load of old 'c' washers (as used to hold the primary gear on) taped together.. or made in the lathe/mill from hard nylon or steel...
You can knock them out with a punch/drift too - but tis a bit of a game..
HTH,
Dave
Edited by icklemini, 09 February 2007 - 10:55 PM.
#4 nomininolife
nomininolife
  • 982 posts
Posted 09 February 2007 - 11:23 PM
Hi Dave
Thanks for the reply
I was going to try the 'C' washers but I cant get hold of any. I had not thought of the old spanner that is a good idea.
I am currently grinding a slot in a first gear to try, that but it is taking more patience than I have at the moment. It maybe a trip to B&Q to see if they have something suitable.
David
#5 icklemini
icklemini
  • 2,982 posts
Posted 09 February 2007 - 11:52 PM
Hi Dave
David
see if you can find a chunk of hard nylon - the stuff like the solid subframe mounts as its easier to turn into a horseshoe shape!!
or the local carboot / market where you can get a cheap large open ended spanner to chop up :angel:
good luck :w00t:
ttfn,
Dave
Edited by icklemini, 09 February 2007 - 11:54 PM.
#6 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 10 February 2007 - 12:26 AM
Weld an old final drive pinion nut onto a piece of tube and then weld that to a nut that fits on the end of a slide hammer.
Works for the first motion shaft too.
#7 nomininolife
nomininolife
  • 982 posts
Posted 10 February 2007 - 12:43 AM
Without trying to sound too daft, its ok with the slidehammer on the pinion end, but to me there isnt enough clearance on the diameter of 1st gear to clear the bearing housing.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 February 2007 - 03:10 AM
Well I use something a lot simpler
Get a piece of hardboard/MDF and a hole cutter and cut out a few doughnut shaped sections then cut a 'bite' out..
#9 nomininolife
nomininolife
  • 982 posts
Posted 10 February 2007 - 09:34 AM
Thanks John, I never thought of using wood. Can I take you up on the offer of pic's please?
Many Thanks
David
#10 icklemini
icklemini
  • 2,982 posts
Posted 10 February 2007 - 05:24 PM
correct - the slide hammer route works fine - but you still need *something* in there so that 1st doest catch against the web.
Yep - a horseshoe shaped piece of wood would work too...
TTFN,
Dave
#11 nomininolife
nomininolife
  • 982 posts
Posted 12 February 2007 - 10:11 PM
Just to let you know, the horseshoe shaped piece of wood worked like a dream.
Many thanks
David
