Pre engaged (non) starter
Posted 10 February 2007 - 06:11 PM
I got a new started from a scrap yard, fitted it, connected it and it doesn't even click!!!!!! i've had the car on charge and ive tried rocking it in gear to free it up. Is there anything i can try?? can i recondition the one i took off??? i'm a bit miffed!!!!!
Posted 10 February 2007 - 06:14 PM
Posted 10 February 2007 - 06:16 PM
Posted 11 February 2007 - 04:21 PM
I took the "new" one off and put the old one back on.. the one i have from the scrappy doesnt move in either direction so i'll be taking it back to get my refund on monday!!!
The starter turns over a bit better than it did, though i've had the battery on chatge for 24hours.... turns over fine with spark plugs out.
Posted 11 February 2007 - 06:21 PM
inside of the starter will be bush's when these are damaged they can become tight slowing the rate of the starter down aldo if theres bad conections ontie inside on the armature then it would slow, anyway of taking the sol' of the slow one and putting it onto the non clicker? (i havent worked on mini starters by the way so kinda unsure of the construction
Posted 11 February 2007 - 06:27 PM
Posted 11 February 2007 - 06:57 PM
Posted 11 February 2007 - 07:14 PM
Posted 11 February 2007 - 07:17 PM
Posted 11 February 2007 - 08:05 PM
Posted 11 February 2007 - 08:24 PM
Gav, I've got a working Pre engaged Starter in the Garage, let me know if you want it!
whats yer price???
Posted 11 February 2007 - 08:34 PM
Posted 11 February 2007 - 08:45 PM
Posted 11 February 2007 - 08:49 PM
the starter just seems to have too much work to do, if i slacken one spark plug it goes, also if i push it gently foreward and drop the clutch whilst pressing the start button it spins really quick and starts every time... just not very convenient to do it every time i go out.
Posted 11 February 2007 - 08:56 PM
Dave
