Whats the thread size?
5 replies to this topic
#1 $way
$way
  • 720 posts
  • Local Club: ...
Posted 11 February 2007 - 01:51 PM
i need to know the thread size on the discs i have they are standard 8.4" ones.
i need some bolts to mount the discs on the drive flange.
J
#2 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 11 February 2007 - 08:45 PM
best get them from a dealer
the torque for these bolts is higher than the normanl bolt. for safety reasons, but i think they are 5/16UNF, or 3/8 if you used a 1/2 socket then there 5/16 if you used a 9/16 then there 3/8UNF.
hope this helps
#3 $way
$way
  • 720 posts
  • Local Club: ...
Posted 11 February 2007 - 11:55 PM
i know they have a higher torque setting but surely they are just high tensile bolts. dealers arent going to have special bolts are they??!
does that make sense?? im very confused could you explain it again please?
#4 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 11 February 2007 - 11:56 PM
if the bolt head is a 1/2" socket, the thread will be 5/16UNF
if the bolt head is a 9/16" socket, the thread will be 3/8UNF
#5 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 12 February 2007 - 12:09 AM
3/8UNF but be sure, i've come across some nasty M10 metric fine thread ones there too!! i think they are more metro fitment tho, just so u are aware!!
#6 $way
$way
  • 720 posts
  • Local Club: ...
Posted 12 February 2007 - 12:45 PM
cheers,
ill be sure to get high tensile ones.
ive got some metric nuts/bolts lying around at home so ill check if its 10 mm but i doubt it will be.
J
