Valve has stuck open on Freshly built head
Posted 11 February 2007 - 06:38 PM
New valve guides
Cleaned up valves
Reamed the guides to fit the valves
Re-cut the valve seats
Lapped the valves in
Cant think I've missed anything
but the started car up ran for about twenty mins quite happliy then an exhaust valve stuck open
Anybody any idea what would cause this?
Valve isnt bent if you hold it against a start edge but the end has been swollen by the rocker hitting it
Posted 11 February 2007 - 08:26 PM
i had a problem in canada, put all new valves in a Car for Snshine, a few miles down the road it started to tap,. took the head of after being recovered to find on of the valve heads had fallen off. total right of of the engine, head and pistons all damaged.
hope it hasn't done any damage to anything else.
Posted 11 February 2007 - 08:29 PM
Posted 11 February 2007 - 10:52 PM
were the new guides reamed out after fitting ?
indeed - the guides need reaming out once pressed in.. - Though you say they were reamed - Sure this was done right?? (if the machine shop did it then send it back to them!)
TTFN,
Dave
Edited by icklemini, 11 February 2007 - 10:53 PM.
Posted 12 February 2007 - 09:40 AM
Guides were reamed out, and I did them so I'm confident it was done right.
Posted 12 February 2007 - 07:14 PM
what clearance did you allow between the valve stem and the guide?Not new valves and the valve head hasnt detached its self
guide/valve material mismatch?
Bent valve?
Overheating?
Posted 12 February 2007 - 08:03 PM
Didnt have internal micrometer so did them by feel and they all felt the same and would drop thru the guides by their own weight - not brilliant I know but I've done it that way before
Not according to Keith Calvers articles
Bent valve?
Well it wasn't but it is now after close checking!
Overheating?
No
Edited by Udo, 12 February 2007 - 08:04 PM.
Posted 13 February 2007 - 12:52 AM
0.0015" clearance on the stem diameter is the absolute minimum
usually a 9/32" ream or a 7.14mm with new valves
Iron guides - chrome stemsguide/valve material mismatch?
Manganese-bronze guides - well anything really, but the nitrocarburised ones wear better...
I have come across it before - I put it down to the oil seal being a bit too enthusastic - there was a seal on the exhaust valve, not normally needed as oil dont flow 'down' them stems to burn.. :\ did you put seals on the exhaust valves??
TTFN,
Dave
Edited by icklemini, 13 February 2007 - 12:57 AM.
Posted 13 February 2007 - 01:32 PM
Also if you look at the mini expert mag it shows KCalver putting his uprated seals on all valves so now i'm confused
Posted 13 February 2007 - 02:11 PM
As mentioned, 0.0015" clearance should be your target. Internal mics may be of some use but the way I check small bore holes like this is with "plug gauges". Basically they are precision ground rods with tightly controlled diameters. Most machine shops have them for inspection purposes.
In-spite-of what KC may have said, read up on valve guide material and valve stem material. There are small differences in the coefficients of thermal expansion and this may dictate minor changes in the "cold" tolerance you apply to the reamed guide diameter you choose.
Posted 13 February 2007 - 06:59 PM
Posted 14 February 2007 - 12:20 AM
i think lawson is onto something, forgot all about heat expansion, look at the valve when it comes out and see if it was 1 spot that caught (dirt/grit) or if its scuffed all round like its been clamped!!
exhaust does run hotter than inlet..
exhaust valve has nothing but hot gas going over it.. inlet has a nice cool inlet charge cooling it.
inlets dont get as hot.are on the inlets as standard and dont usually make them stick.
exhaust valves dont need the seals as any #spare# oil that gets down the guide is blown back up the next time the exhaust valve opens (all that gas coming out of the chanber)
the inlet valve, however, when open has a 'suck' act upon it, pulling air into the chamber, and without seals, oil will be drawn down the guide because of the vacuum...
i only put seals on inlets to be honest..
ttfn,
Dave
