depends on you spec really, and if you use it on the road, as you could put a very high final drive in it,(good accel) but then it would be reving its nuts off at 70mph
i think the standard fd for a 1275 engine before injection, was 3.4 the citye 1000 had a 2.9 you could go for a 3.7, i think you can get a 4.1?? (not sure about that tho) but you might find if you put a 4.1 in it, you wouldnt reach the 80 - 90mph top speed before the 1/4 mile was over.
and if your loaded, you could always buy the new jacknight CloseRatio StraightCut DOG 5 speed gearbox
but there 1200 quid or somthing!!
Youd probably be better off buying a Close Ratio gear set from mini spares! so you keep your gearbox and just change the gears inside!
So whats the rest of your spec? if its standard theres other things you could do first!
Dave
thats probably quite a vague description, imsure someone will better it!
Edited by Mini-Dave, 12 February 2007 - 11:39 AM.
