Tacho
2 replies to this topic
#1 Hussar
Hussar
  • 88 posts
Posted 12 February 2007 - 09:06 PM
After fitting my new custom loom which by the way is working fine and seems to have solved all of my many electrical problems it is time to refit the dash. When I connected the tacho it still has the same fault as it did pre new wiring loom. It is intermittent in its operation i.e. sometimes it works sometimes it doesnt. Any pointers in how to fix this will be greatly appreciated.
#2 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 13 February 2007 - 12:09 AM
my tacho was jumping all over the place then packed in on me totally,
turns out the wire to the coil was loose then came of, i put back on and worked but still jumpy, a new coil solved the whole problem and i can tell the rpm now!
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 13 February 2007 - 12:21 AM
Same here. loose wire on the coil, tightened it up and it was sorted.
