grill buttons
Posted 03 October 2004 - 06:29 PM
anyone tell me how they go on?
Posted 03 October 2004 - 06:42 PM
Posted 03 October 2004 - 07:43 PM
Posted 03 October 2004 - 09:42 PM
With the grill still fitted carefully drill a hole through the grill (between) the slats into the front panel supports (the 2 bars that go from top to bottom) remove the grill and the drill all the way through. then fit the 2 nuts and bolts to the support. then refit the grill using the buttons to secure it.
Siggy
Posted 03 October 2004 - 11:52 PM
I prefer the "older" style that I have to those available now. Mine have extended "stems" on the back side of the buttons. These stems go between the grille slats and push the flat grille panel against the car's front panel. The newer style grill buttons use a rubber washer on the back side of the grille button... and this pushes on the grille slats themselves.
Posted 04 October 2004 - 12:01 PM
Two 1.5 inch pozi-drive screws ( wood screws basically ) through the grill into the front valance ( about where you would put the buttons )... does exactly the same thing and also has the bonus that the screws fit between the slats so you cant actually see them... ( just got to remeber to have a philips screw driver handy )
Posted 04 October 2004 - 12:23 PM
Posted 04 October 2004 - 12:39 PM
You can still get the buttons with the stand-off built in from some places. They are quite similar to the roker cover buttons, but I think the stud size is different.
Posted 04 October 2004 - 05:04 PM
You are correct. The stand-off grille buttons that I have use a 5/16-24 stud while the more current products I've seen use 1/4-28 studs.
Posted 04 October 2004 - 09:25 PM
Thinking about it now I'd be inclined to weld a nut on the panel, and have an Allen or Torx bolt through....Still allows for the quick removal but hides away the head in the grill
Posted 05 October 2004 - 09:24 AM
Posted 05 October 2004 - 12:11 PM
Posted 05 October 2004 - 08:02 PM
Siggy
