Posted 18 February 2007 - 08:27 PM
Posted 18 February 2007 - 08:29 PM
Posted 18 February 2007 - 08:46 PM
Hi Thanks for getting back,I think the clamp is coming loose that joins the exhaust to manifold flange, and I suspect all they are doing is tightening the clamp and adding sealant, and it's not holding, a few journeys over speed humps and I think its working loose, used Kwik fit because found it difficult to reach but since then have now got some ramps, the mini's due back at Kwik fit tommorrow for them to have another look, but thanks will try and repair ourselves if it happens againComing away from the manifold?
Is this an uprated manifold (LCB or freeflow) or the old stock manifold?
If its the orginal manifold then I'd do two things, 1st would be put the two manifold flanges back tight together then put the clamp. 2nd I would check the lower exhaust mount on the back of the gearbox was still attached.
...also wouldn't be using quick fit.
Posted 18 February 2007 - 08:52 PM
Posted 18 February 2007 - 09:02 PM
Edited by taffy1967, 18 February 2007 - 09:07 PM.
Posted 18 February 2007 - 09:07 PM
Posted 18 February 2007 - 09:11 PM
Posted 18 February 2007 - 09:19 PM
Posted 18 February 2007 - 09:39 PM
