How do I fit a front nudge bar?
Posted 19 February 2007 - 05:58 PM
I have just bought a set of nudge bars for my Mayfair and was wondering how to fit the front one. I would guess that the bottom part feeds into the holes under the bumper but does the top part screw into the bonnet?
If you have fitted nudge bars to your Mini please let me know how it was done as I don't want to screw into the bonnet if this isn't needed.
Thankyou
Del
Posted 19 February 2007 - 06:08 PM
I imagine it attaches to the front subframe mounts?
For example:-
Wood and Pickett Nudge Bars Link
Edited by taffy1967, 19 February 2007 - 06:14 PM.
Posted 19 February 2007 - 06:09 PM
remove the subframe mounting bolt from the little holes eather side of the number plate
but the ends of the nudge bars into these holes them refit the bolt from the inside screwing into the nudge bar
as for the top i dont know
Posted 19 February 2007 - 06:23 PM
I've never fitted a set myself, but I certainly don't think you should attach the front one to you're bonnet. You'll never get it open again if you do?
For example:-
lol oh dear of course, I'm such a muppet. Dont want the bonnet being screwed closed! lol
Are there screw holes under the bonnet either side of the bonnet release(or lock, the middle bit).
Maybe it screws on there.
Thanks for your help guys
Posted 19 February 2007 - 06:25 PM
i dont have nudge bars but my sopt light bar fits the same way at the bottom
Thanks Bungle i'll take a look at that.
Del
Posted 19 February 2007 - 07:01 PM
Posted 19 February 2007 - 07:20 PM
if it's a wood and picket, it connects to the two towing eyes on the front subframe, if you don't have the towing eyes then you'll need to get some... The top bracket(s) are bolted to the slam panel ( this is the one the bonnet 'slams' against).
Brilliant thanks.
So I assume there is bolt holes on the slam panel? Or do I need to make some holes?
Del
