Thickness of sills
11 replies to this topic
#1 Leonard
Leonard
  • 784 posts
  • Local Club: mini rebels
Posted 07 March 2007 - 06:56 PM
Evenin all! After my best ever MOT fail, i have a bit of welding to do, no probs as im a welder. But I've never done any bodywork welding before. The drivers side outer sill has two holes in it, one around the jacking point, and one at the very front.
So, what thickness of plate are the sills made of, and what thickness should i repair it with? We use mostly 3mm-6mm, but i think there maybe some 2mm about. And we use 1mm wire, is this thin enough?
This is only temporary, ill do it properly in the summer!
Leonard
#2 luvlygal
luvlygal
  • 1,297 posts
Posted 07 March 2007 - 06:59 PM
Where do you live? My mini needs welding... ;)
I can't help you though, I'm a woman. Some people on here seem to have a problem with us and cars =]| :D
Edited by luvlygal, 07 March 2007 - 07:00 PM.
#3 Leonard
Leonard
  • 784 posts
Posted 07 March 2007 - 07:01 PM
gloucestershire, i work near stroud, but to be honest, i dont even want to weld mine!
#4 luvlygal
luvlygal
  • 1,297 posts
Posted 07 March 2007 - 07:02 PM
:D Booger! No worries! I was being cheeky! =]
#5 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 07 March 2007 - 10:18 PM
i use 1mm plate and 0.6 welding wire with my mig welder, i wouldn't use anything thinner unless its an actual panel
#6 Leonard
Leonard
  • 784 posts
Posted 08 March 2007 - 06:52 PM
thanks cowboy. i found some 1.5mm plate at work, and ill do that tommorow. Im still digging and the hole is 6" by 2" so far!
#7 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 08 March 2007 - 09:45 PM
i tried weldin mine but found the hole got bigger n bigger, like weldin tissue paper! lol
finally just got the whole replacing job done in the end, saves time in the long run!!!
#8 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 09 March 2007 - 07:37 AM
.6mmwire for sure and like tin plate 18 or 20 gauge to you, but the stuff you use is great for roll cage applications
dave
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 March 2007 - 08:29 AM
I use various sections of repair panels I have lying around for patching...
#10 sqweaka
sqweaka
  • 678 posts
Posted 09 March 2007 - 09:52 AM
make some sills from the 6mm stock you have at work and you'll not need to do them again for another 100 yrs. haha
Edited by sqweaka, 09 March 2007 - 09:53 AM.
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 March 2007 - 10:01 AM
PML :P only slightly over engineered ^_^
#12 Leonard
Leonard
  • 784 posts
Posted 10 March 2007 - 11:12 AM
hi guys was tempted by the 6mm, but what with me and the brunel style sill on the same side, it might lean a bit.
jobs done now tho, used some 1.5mm plate. i also had to put a 4" x 3" patch on the inner sill, which i welded inside and out. ended up replacing about a 3rd of the sill with new plate. it took me 4 1/4 hours which i thought wasnt too bad, as ive never done any bodywork before. and never again!
thanks for the help
