HI Spud, this is an interesting thread for me as my left knee got severely damaged as a result of a scooter accident last year and my Mini has been laid up ever since.
I have owned my Mini for 8 years and always felt the clutch was heavy compared to all my old pre-verto cars and intended to overhaul it, but never go around to it before the accident. As my knee is badly damaged and will need replacing at some point, I have to give it as easy a time as possible, so at the moment I am driving an automatic Escort but I would really like to get behind the wheel of the Mini again. My Mini is one of the few pre-accident hobbies I have left and I would be gutted if I had to sell it because I couldn’t use the clutch.
I am planning to do the same as you and replace the clutch but I am also intending to replace the pivot arm and pin, the release baring plunger, slave cylinder and hose and also do as GuesWorks said and lube up the pedal box. If this still leaves the clutch too heavy I am intending to look at smaller bore master cylinders, which should reduce the pedal pressure at the expense of longer pedal travel.
One thing I hadn't considered and I must admit I don't really understand is Line Pressure. A friend introduced me to a neighbour of his who races a historic Formula 5000 single-seater and who also used to own a motor sports part and accessories business. I picked his brain about master cylinders etc, but this guy also mentioned that running a hose with a larger internal diameter would reduce the line pressure and should help give a lighter peddle. I can't really get my head around this as it seems to me you are still moving the same amount of fluid for a given force at the peddle, but it's something I’m going to look into if overhauling the clutch assembly doesn't reduce the peddle pressure enough for me to comfortably drive the Mini.
My Misses has asked why I don’t convert the mini to an auto-box, but having driven my friends Clubbie Estate auto, I have to say it was probably the worst gearbox of any vehicle that I have ever driven (even worse then the CVT box in my current Escort) and would completely destroy the character of my RSP.
Edited by pogie, 13 March 2007 - 10:46 AM.
